Door trim panel interchangeable?
Discussion in 'Interior Restoration' started by vince72, May 12, 2020.
  1. vince72
    vince72 Veteran Member
    985
    Jul 19, 2003
    orange county california
    On my 72 Camaro will other year door trim panels fit?
    Where have you gents found the best deals?
    Vince
  2. 75Maro
    75Maro Veteran Member
    487
    37
    Mar 31, 2008
    Dallas,Tx
    I’m putting 1970 panels on my doors. One is originally from a 75 and the other is a 78. I ordered from legendary interiors
  3. vince72
    985
    Jul 19, 2003
    I was thinking on the 79 model also. I like how it looks simple and less parts to get
  4. dave@ztech
    3,914
    840
    Mar 27, 2016
    NY
    Zulu28, BillyDean7173, 73 Z and 2 others like this.
  5. dave@ztech
    3,914
    840
    Mar 27, 2016
    NY
    That is a 78 panel on a 71 with 67 door pulls
  6. vince72
    985
    Jul 19, 2003
    A lot less parts and it looks good.
  7. badazz81z28
    17,810
    709
    Alabama
    The 70-81 Doors are the same dimensional wise. The inner structure is slightly different from 75 on as the door pull changed and the door release handle was riveted and sitting inside the door versus being bolted on in 70-74. You can easily install any year panel the only issue I think you'll come across is if you try to use a 75-81 door pull as the sheet metal for the upper screw is bulged and angled for it. The 70-74 door is flat. I like the idea of using a later one piece panel if your not going for period correct.
  8. vince72
    985
    Jul 19, 2003
    I appreciate the info, I would need some photos to better understand the differences to see what I’m up against.
    Much appreciated
  9. 73 Z
    1,026
    38
    Jun 9, 2007
    Los Angeles, Ca
    70/74 doors with 79/81 panels
    70 to 74 camaro.jpg 70 to 74 door  LH.jpg 70 to 74 door.jpg 75 to 81 RH door panel.jpg
    75/81 door/handle/panel
    My scussions are upside down, was the only way I could have it mount below 75/81 trim. Are the 75/81 handles the trick to make it right?
  10. vince72
    985
    Jul 19, 2003
    Sorry what are scussions?
