door/window weatherstrips
Discussion in 'Body Restoration' started by arnies81camaro, Sep 11, 2012.
  1. arnies81camaro
    arnies81camaro Member
    59
    Aug 20, 2011
    groveland,ma.
    Can anyone recommend a brand of weatherstips for my 81 camaro? I bought a set of OER weatherstrips and after installation you have to slam the door to close. they are really thick and stiff weatherstrips! I called OER and they said try a heat gun on them or lay them out on the asphalt to warm them up! so they went in the trash! I'm looking for a set that will fit nice and the doors close easy! Help!!!
  2. GOLF72
    GOLF72 Veteran Member
    2,186
    Jan 11, 2010
    CORONA, CA
    OER is good but I like Metro or Soft Seal. Anyway, over a period of time by opening and cloisng your door the weather stripping will take its form and the problem should reduce or go away completely. Mine did...
  3. bnelson
    bnelson Member
    99
    Dec 1, 2010
    San Marcos,Texas
    I had the same problem with my OER but you need to let them form to your window. It took time and patience.
    What helped me was to armor-all the weatherstripping so the window would close easily or at least more easily than when it was dry. If they were dry you'd have to reef on them too much.
    I also rolled my window up all the way, shut the door fully, and used a hair drier to heat up the mating surfaces. If it would have been in the summer, I would have just parked it in the hot TX sun.
  4. CDesperado
    3,591
    83
    Oct 1, 2004
    Dallas Texas
    Buy the MetroMold kit from FBodywarehouse.
    The SoffSeal ones are known to be of poor quality. Aces bought a set and posted up some pics of what they looked like after only a year or two.
  5. Keizer
    Keizer BANNED
    7,971
    Jan 17, 2005
    Wa State
    I used Metro on my doors and upper roof rails. I was really happy with the result. I have often wanted to record the sound of my doors shutting because it sounds perfect. :D
  6. aps63
    aps63 Veteran Member Lifetime Gold Member
    476
    Sep 4, 2007
    N.J.
    I used all Soffseal and really liked the quality and the way the fit.
    Just my opinion.
  7. arnies81camaro
    59
    Aug 20, 2011
    groveland,ma.
    I just ordered the metro weatherstrip seals! I'll let you know how they fit! thanks for the info...
  8. TDPalmer
    TDPalmer Veteran Member Lifetime Gold Member
    823
    Apr 25, 2011
    Cave City, Arkansas
    I use Metro too, I like the 15 year replacement warranty no questions asked. :)
