1977camaro owner said:Dirt.
Keep up the good work and keep us informed on these Vortec Heads From the size of the view's it seems to be appreciated by alot of people
Thanks for the words, much appreciated.
Welcome to Nasty/Z Dave, I thought I seen you on another site before.Greg Mariettti's book " How To Run 11 Second E.T's"
https://www.thirdgen.org/forums/tech-general-engine/770493-book-quikie-racing-how.html
Shift it at 6800 or 7000. It's a small block. Remember POWER IS IN THE CYLINDER HEADS, it's just a big air pump. Air Flow Research 195 Eliminator heads are unreal.Well I am Finally putting my 77 Back on the Road With a moderate street 355 I have been waiting since 2002 ,To finally convinced myself not to let this car be a drag car And It deserves More street attention, A mint no rust ever car original floor pans etc.working on that project now. I finally don't want to batter my second Gen Anymore.
My next question needs some drag race expertise we have finally decided to make my sons 1987 3rd gen a designate drag car Please let me know if I am Headin in the right direction re: a build up Bringing weight to 3250 With driver
383 Stroker W/062 Vortec Heads ,xe274s Solid flat tappet 501/510,236/242 @50*Flat top speed pro Pistons with coated skirts Hoping to get 10.3:1 Comp
Victor jr Intake 750 Holley D/P Carb 350 Turbo trannie w/tci 3500 Stall 5.7 bushed rods 7 Qt Pan With Windage tray and crank scraper, 1 5/8 Long tube headers w 3" collectors 410 Gears 28" Slicks block decked to .005 This block is fresh machining wise .30 over Bored Torque plated and honed
Changes to car definately lightened up to 3000 Plus driver front 90/10 drag struts moroso trick coils rear CE ladder link bars Coil overs with an 8.5 donor 410 rear end with c-clip elim and spool standard steering Electric water pump Electric cooling fan Hoping to shift at 6000 and run 11:50'sor so Do you think this is possible Iam open to any suggestions to make this better as There seems to be alot of smart people giving advice on this forum Should I change my lobe centre line to 104 by advancing the cam or just put it in straight up @106 Do I have enough cam in the first place?? Your help would be much appreciated I also have the option of going with Aluminum heads flowing 252cfm @ 500 Lift would this be much bbetter than the vortecs?
Thanx Ron
