Drag racing Front suspension
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by muscl car, May 10, 2021.
  1. muscl car
    23,284
    1,728
    Jul 8, 2001
    Hendersonville Tennessee
    Looking for advice on setting up a good drag racing Front suspension for good weight transfer . Currently running stock upper / lower A arms , Moroso Trick front springs and QA-1 Double adjustable drag shocks
    Looking at going to tubular A arms and using Moroso Trick front springs and my QA-1 shocks
    My rear suspension is all Calvert racing components ....
    Cal trac bars
    Split mono leaf springs
    Single adjustable shocks
  2. camaro71/holland
    1,494
    196
    Aug 27, 2003
    The Netherlands
    The basics are IMO:
    unbolt or at least loosen front sway bar,
    Prevent binding as much as possible by using spherical joints as much as possible,
    run everything as loose as possible and as tight as necessary,
    Set toe in/out at 0°
    Clean, grease and don't overtighten front bearings
    Rest is up to your wallet, but TRZ makes some very nice stuff.
    muscl car and xten like this.
  3. Scott51
    Scott51 Veteran Member
    734
    108
    Jan 2, 2012
    New Zealand
    TRZ arms + AFCO coilovers is a really nice setup but depends how much you want to spend
  4. Fbird
    5,605
    1,549
    Feb 12, 2011
    atlanta, ga
    Camaro71.....pretty much covered it. ;)
