Driveshaft ID stripes
Discussion in 'Original Drivetrain Topic' started by CamaroNmotion, Aug 7, 2016.
  1. roeville
    roeville Veteran Member
    1,276
    116
    Oct 9, 2000
    SF East Bay CA
    Very interesting. Mine is black but was definitely repainted before I owned the car. I always thought they were originally unpainted.
    Mike
  2. Peter Wilson
    Peter Wilson Veteran Member
    574
    Nov 24, 2006
    Chance Harbour ,N.B. Canada
    The primer on my driveshaft is much heavier on one side than the other , very light covering on one side with a slight amount of surface rust starting to show through , 180 degrees around to the other side the red oxide is much heavier with no surface rust coming through . the original u-joints and slip yoke are still installed on it as well . ive very carefully inspected it for any indication of stripes on or under the red oxide and see no indications of any . It does not seem to follow the same finish as any of the others that I have read about on here so maybe it was a service part ?? warranty replacement ? My car has only 11,000 miles and was taken off the street permanently in '72 and turned into a dragster . I know the Turbo 400 and 9" rear were put in the car early in its life as a dragster but possibly not until after a year or 2 after it was transformed into a race car . I know the original owner raced it with the M21 for the first year before he went to the T400 . Im sure the rearend and driveshaft were replaced with the 9"around that time as well . It is possible that he might have had to replace the shaft with a service part prior to removing the 10 bolt and M21. I will ask him next time Im talking to him . there are no dents or damage to the floor boards from a driveshaft or U-joint failure though.
  3. joebarber
    joebarber New Member
    Jul 26, 2011
    st joseph,mo
    . Would you be able to share you're pics and measurements for you're driveshaft? I have a 70 Z28 automatic Van Nuys built. I'm to the stage of detailing the shaft and would like to only do it once
  4. x77-69z28
    x77-69z28 Veteran Member
    387
    33
    Feb 5, 2010
    long island, new york
    I would be interested too. I have an 04D Van Nuys Z/28 auto as well
  5. 2ndGenCrazy
    2ndGenCrazy Veteran Member
    809
    53
    Aug 18, 2011
    Upstate New York
    I am thinking that I read here that the colors were yellow, brown, brown for TH400?
  6. 2ndGenCrazy
    809
    53
    Aug 18, 2011
    Upstate New York
  7. 2ndGenCrazy
    809
    53
    Aug 18, 2011
    Upstate New York
    After I sprayed it with Gibbs Penetrant. This is a Norwood 07C car. IIRC I measured from centerline of "U" joint.
  8. 70 SS/L78
    2,909
    140
    May 5, 2005
    Rockford, MN
    For those of you that have a build sheet, the driveshaft stripe color code will be in box# 19 top row. The color will be abbreviated with 2 letters, such as BK = black or GR = green.
    I'm interested in finding out the color codes for an M22.
  9. KYRS
    KYRS Member Gold Member
    73
    Nov 18, 2009
    Shelbyville, KY
    I have a 04A Van Nuys Z28 Automatic car, My drive shaft appears to have the following colors, measured from the center of drive shaft yoke 14" to 16", looks like a pinkish/orange stripe then brown brown strip. Then a yellow stripe at 27" from the yoke.
  10. Gary S
    23,872
    1,482
    I expect, but can't prove it that a L78 car would have the same stripes as any SS or Z28 with 4 speed as all those cars had the 12 bolt rear and Muncie trannys. The M22 in 1970 still had the same output shaft as the M21 and M20.
