Driveshaft safety loop
Discussion in 'High Performance Modifications' started by muscl car, Sep 10, 2020.
  1. muscl car
    22,775
    1,361
    Jul 8, 2001
    SoCal High Desert
    any of you guy's have a driveshaft safety loop installed on your Camaro , how did you mount it ?????? . I've got a universal kit from Summit and I want to make sure it's installed correctly and that I can pass NHRA Tech inspection
    Last time I installed one was over 30 years ago on a Ford Fairlane I drag raced
  2. Dave Nelson
    Dave Nelson Veteran Member
    4,913
    3,516
    Dec 19, 2003
    Vineland N.J USA
    Some people bolt them to the floor, I would only weld it in.
    muscl car likes this.
  3. Jodi
    Jodi Veteran Member
    473
    261
    May 22, 2019
    Last time I checked, the loop has to be 6" (maximum distance) away from the front U-joint.
  4. muscl car
    22,775
    1,361
    Jul 8, 2001
    SoCal High Desert
    I'm leary of bolting it to the floorboard
  5. 70Znut
    70Znut Veteran Member Lifetime Gold Member
    230
    171
    Feb 5, 2016
    Sarasota,FL
    I have one installed, here a couple pics of the location.
    Mine is currently bolted in with grade 8 hardware.
    Welding is probably better, but I "think" a bolt in will pass tech
    IMG_20160813_141818662.jpg IMG_20160813_134744740.jpg IMG_20160813_134656964.jpg
  6. frankz
    frankz Veteran Member
    2,118
    25
    Aug 24, 2009
    Illinois
    Bolting it to the floor is not an issue if you use flat stock backers. Otherwise no!
  7. Dave Nelson
    4,913
    3,516
    Dec 19, 2003
    Vineland N.J USA
    I'm assuming the driveshaft in the first pic is not fully seated?
  8. 70Znut
    230
    171
    Feb 5, 2016
    Sarasota,FL
    That's correct, it goes in about another inch or so, the angle of the picture is somewhat misleading.
    When seated it was about 6.5 from the center line of u-joint.
    Also, that was an old drive shaft. Here whats in there now.
    dave@ztech likes this.
  9. muscl car
    22,775
    1,361
    Jul 8, 2001
    SoCal High Desert
    Thanks for the pics , now I know what to expect when I install mine
  10. cadillac_al
    cadillac_al Veteran Member
    920
    107
    Apr 22, 2015
    Maine
    I think somebody makes one that bolts to the trans mount. I would hate to drill my floor. I have that universal Summit one on my Impala though.
