Drivetrain Vibration Questions
Discussion in 'Troubleshooting & Diagnosis' started by Glava, Nov 15, 2021.
  1. biker
    biker Veteran Member
    4,332
    2,137
    Dec 7, 2014
    The adjustable upper control arms gave mine nice alignment specs, but really showed up the play in my 3rd gen iroc box. I read somewhere that the 80/81's have good high speed aero. Certainly not as nice a look as the 70-73, but they manage the wind pretty well.
  2. ClassicRob1977
    ClassicRob1977 Member
    87
    42
    Jun 21, 2021
    Whatever came of this? I am having a SCARY vibration at 80+. I ran a bolt on coyote the other day and when I let off I was thinking I broke something. I have not even attempted those speeds since. I really need to figure this out..
  3. Glava
    Glava Veteran Member Lifetime Gold Member
    444
    41
    Mar 23, 1999
    Central NY
    OK, here is the recap of where I'm at;
    The tires have been road force balanced 2 times.
    Tires at 30 psi -no odd wear patterns etc.
    Rotated rims and they don't wobble or have dents.
    Rotated tires front to back etc. -still have vibration.
    Checked and verified front wheel bearing adjustment.
    Checked drive shaft, no spot that looks like a missing weight
    U-joints tight.
    No side to side or in/ out movement near rear of driveshaft.
    Again -this Z has 31k miles and I have serviced the front suspension regularly, changed rear gear oil/ posi additive at least 3 times.
    I finally got the Tremic APP and checked the pinion angle -checkmate 201, I think that you had mentioned this first and this looks like it may be the problem -tell me what you think ... Rear 0 degrees, driveshaft 2 degees, trans 15 degrees and the APP says that I'm not in specs.
    So, I have never fixed anything like this, but everything I have found, indicates that I should target 3 degrees front, 3 degrees rear -with them in opposite directions but parallel.
    Am I understanding this right?
    If so, the trans is negative 15 degrees -so I need to bring it up with shims or??? to get to -3 degrees
    Then try to raise the rear at the pinion to get to + 3 degrees -how do I adjust this?
  4. Jodi
    Jodi Veteran Member
    919
    655
    May 22, 2019
    Collapsed Engine/Transmission mount?
  5. BonzoHansen
    20,991
    1,931
    Jun 1, 2005
    Scott from Hamilton, NJ
    15*? That can't be right or the mount is broken or wrong.
  6. G72Zed
    G72Zed Veteran Member
    3,487
    1,903
    Sep 8, 2015
    A 15* downward engine trans angle is out to lunch, how did you measure the trans angle, or more importantly, what surface did you use? something is not right. A 15* angle will induce carb issues to a point.
    And you do not want to setup a leaf car with equal and opposite angles at rest, if so, you will have + pinion angle at speed due to axle wrap, and get's worse when you "getting on it".
  7. Glava
    444
    41
    Mar 23, 1999
    Central NY
    Oops its 5 degrees not 15 degrees -sorry. I put a straight edge across the tranny output at the seal.
    So what would you recommend that I try at this point?
  8. Bandit723
    Bandit723 Veteran Member
    3,818
    740
    Oct 1, 2016
    Waupaca WI
    I would go for 2.5 degrees at the tranny or engine to start. some shims may help but i suspect the setup is leaning back to far.
  9. checkmate201
    checkmate201 1970 SS 350 4sp 06 C
    39
    20
    Dec 30, 2005
    Nanaimo B.C
    MChamp likes this.
  10. COPO
    21,353
    2,782
    I don’t believe the factory created this problem and couldn’t fix it under warranty. I ordered new 4 speed Z28’s in 77, 78 and 80 and never had a vibration. Maybe I was lucky but I dought it.
