Drivetrain Vibration Questions
Discussion in 'Troubleshooting & Diagnosis' started by Glava, Nov 15, 2021.
  1. Glava
    Glava Veteran Member Lifetime Gold Member
    444
    41
    Mar 23, 1999
    Central NY
    Not so sure about that -it has done it since 79, but I never brought it to the dealer to correct. I love this Z and that is the reason I've kept it for 42 years, but there were 84k of these built and mine was a June 79 build. If you saw how bad the fender gaps are and how the factory paint fades at the bottom of the rockers and the rear bumper, there are definitely things that snuck through QC in those days.
  2. Glava
    444
    41
    Mar 23, 1999
    Central NY
    Thank you!
    This reinforces what my head had gotten to at this point.
    The trans output seems to be a couple of degrees too low -at least IMO. So, I found a nice set of GM shims that are sized for the GM crossmember. There are 4 that are 1/8" thick, so I'm going to try these and see what happens.
  3. COPO
    21,353
    2,782
    I would have kept bringing the car back under warranty until it was fixed.
    I had a water leak in the trunk in my 78 Z28. It took 3 different trips to the dealer before they found sheet metal that was not seam sealed. Many of the stripes on the 78 were peeling around the wheel wells so GM nearly replaced all the stripes.
    Bad adhesive.
  4. G72Zed
    G72Zed Veteran Member
    3,487
    1,903
    Sep 8, 2015
    That makes more sense. With the car on level ground, the engine tilt should be around 2-3*, using the damper or even the intake carb pad works well as the intake carb pad has this designed into it in most intake castings, since the carb was designed to work level. Shims at the trans mount should work to get you into the right zone, or a new rubber mount.
    Here's my "rules" to setup driveline operating angles.
    # 1- 1 to 3* angle, Min. 0.5* Max. 3.0*
    # 2 - Must be within 1.0* operating angles of each other
    # 3 - Front to rear must be opposite
    # 4 - Check rear end location for excessive offset "compound angle"
    # 5 - Adjust rear axle pinion angle based on spring pack & bushings, TQ/weight of vehicle.
    You want the least amount of total working angles for smooth operation, many forget these cars had engine offsets to the passenger side, and even more offset for the rear ends. Sometimes stacking tolerances got this to the point of a car was just "busy" no matter what was done. Most measure, and focus on total working pinion angles on the horizontal plane only, and forget about the "top view" plane, and this adds to the total compound working angle.
    Glava and checkmate201 like this.
  5. checkmate201
    checkmate201 1970 SS 350 4sp 06 C
    39
    20
    Dec 30, 2005
    Nanaimo B.C
    After you get the angles correct go road test it. If the vibration is still there then mark the driveshaft position on the yoke and remove the driveshaft and have it rebalanced. Once you have confirmed driveshaft angle and balancing is correct you may have an out of balance clutch pressure plate if both of those items do nothing help your vibration.
    Glava likes this.
  6. biker
    biker Veteran Member
    4,332
    2,137
    Dec 7, 2014
    Honestly, I bet that does it. Doesn't take much.
    Glava and MChamp like this.
  7. xten
    xten Veteran Member
    4,476
    3,560
    Sep 24, 2014
    Pittsburgh, Pa.
    At the sake of repeating myself, check the tailshaft bushing in the trans if you have the driveshaft out.
    Glava likes this.
  8. Glava
    444
    41
    Mar 23, 1999
    Central NY
    It's starting to sink in more, so I think that I'll focus on these three. got back under the Z to be sure I really get clean solid angle measurements -I am pretty confident I have them now;
    output shaft 5* down, drive shaft 2* up, pinion 2* up
    I'd like to bring the output shaft up, so that it is only 2* down to match the 2*pinion angle and make their centerlines parallel -is that correct?
    After doing #1, I'll measure the drive shaft/operating angles to see if they are within 1* of each other and fine tune if not?
    They have that orientation now and so should have it after I shim.
    Let me know if I have this right and after this, I'll go on if needed.
    Thanks all for the guidance.
  9. rocket dawg
    rocket dawg Veteran Member
    519
    71
    May 5, 2015
    Grand Rapids Mi
    The car has to be level to check the angles, or I should say, the floor has to be level. You might have to "shim" your jack stands with thin plywood to get them all at the same height. Support the rear axle, then support the front lower A-arms as close to the center of the front tire where it would hit the ground. If you support the front of the car in any other area,( farther back) it will unload the rear axle. These angles being "off" should be felt in the gear shifter at high speeds. Same with an out of whack drive shaft. A new trans mount is cheap, so do that if you need to adjust the trans up or down.
  10. Glava
    444
    41
    Mar 23, 1999
    Central NY
    Thanks again G72ZED, Checkmate and others!
    So I got a new transmission mount as long as I was going to try and correct the pinion angle with shims. When I took the original one out, I realized it was collapsed. It was approximately 1/4" shorter than the new Anchor industries mount.
    I installed it without any shims and the angles were 4* at tranny and 2* at the pinion. The driveshaft angle is 3*.
    It seems that this is good -right?
    at pinion. It seems that this is good -right?
    TOOK IT FOR A LONG TEST DRIVE AND THE VIBRATION IS STILL THERE AT 70MPH -NONE IN THE STEERING WHEEL, BUT IN THE SEAT OF MY PANTS.
    If so, I'm on to getting the driveshaft balance checked -right?
    If so, I'm on to checking the tranny tail shaft bushing and then getting the driveshaft balance checked -right?
    My bad,
    Dave Nelson and xten like this.
