Dry sump set up for my LS3 swap
Discussion in 'High Performance Modifications' started by Gasoholic, Apr 10, 2020.
  1. 71RS/SS396
    71RS/SS396 Veteran Member
    2,640
    43
    Aug 26, 2008
    Wake Forest NC
  2. Gasoholic
    Gasoholic Veteran Member
    198
    82
    Apr 2, 2019
    MI
    The Tilden looks a little nicer I think.
    Thanks for the links
  3. Lowend
    16,540
    1,300
    Mar 25, 1999
    San Jose, CA, USA
    I know nothing about Champ one way of the other. But I’ve seen the Tilden first hand and can speak to the quality.
  4. dave@ztech
    [email protected] Veteran Member Lifetime Gold Member
    4,653
    1,073
    Mar 27, 2016
    NY
    I was watching a video, will see if I can find it, anyway the guy is a driftcar guy and oil control is very important, espically because they also use LS based engines that have a couple of oiling problems, and he uses the dry sump and another type of system on another car called accusump ?? found the video just skip around till you find the part where he goes over each system
    Gasoholic likes this.
  5. Gasoholic
    198
    82
    Apr 2, 2019
    MI
    Cool video.
    Looks like he's using the 3 stage system. Looking at the clearance between the pump and motor mount I'm not sure a 5 stage would fit in that configuration.
  6. dave@ztech
    4,653
    1,073
    Mar 27, 2016
    NY
    It's the part about the accusump, that has the longish tank mounted in the rear, that pumps in oil when needed, that system is maybe 800 dollars and looks like lots of people use it, no one is saying it is as good as a true dry sump, however, they all argee , it works and is less money out of pocket, that is the system I would look at , while saving my nickles and dimes for a really nice dry sump system, we just need a few more players in that market, and then the price will go down, HAA HAA
  7. Lowend
    16,540
    1,300
    Mar 25, 1999
    San Jose, CA, USA
    Accusump is a great safety measure for race engines. When oil pressure drops, it dumps extra oil into the system. When the pressure goes back up, it gets pushed back into the sump.
    https://www.cantonracingproducts.com/accusump
    They've been a standard for road racers since before I was born.
    I did have a very smart mechanical engineer tell me he'd done the math and their pre-oiling (prior to starting the engine) claims were impossible due to pressure constraints.
  8. Gasoholic
    198
    82
    Apr 2, 2019
    MI
    Some good links here, thanks!
    Once I get the frt end back together I'm going to do some experimenting with positioning the motor and see how much clearance I got.
