Drywall gurus
Discussion in 'The BS Topic' started by gin man, Mar 10, 2015.
  1. 80sz
    80sz Veteran Member
    3,845
    713
    Feb 2, 2014
    Buffalo,n.y.
    Mesh here also,I cover it with a thin layer of durabond90,perfect for big gaps,and a first layer,it sets hard.
  2. grzewnicki
    3,514
    226
    Dec 9, 2009
    Gordon from Jacksonville Fl
    Yep, use a setting (durabond) type mud (comes in bags-powdered, has a little bit of plaster of paris in it) and use paper tape. That will be a good strong first coat, and it dries fast. You really want just a thin layer of mud under the tape, enough to adhere it to the drywall. For the 5 gallon buckets of mud... always mix your mud with a paddle mixer with a good 1/2 inch drill bit and you may need to add a cup or two of water to get it to the right consistency. Straight out of the bucket regular drywall mud is just a bit to thick.
  3. onelapduster
    onelapduster Veteran Member
    720
    May 5, 2010
    South Joursey
    Thin layer of mud.
    Then lay in wet tape, put it in a 5 gallon bucket of water.
    Set it in with a little mud.
    My wife and I renovated our 1900 sqft house, that's the way we did all of the joints. Zero issues after nearly 10 years.
  4. Buickfunnycar
    Buickfunnycar Veteran Member Lifetime Gold Member
    8,370
    1,075
    Nov 11, 2005
    living the dream in my own world...
    Oh man...ain't that the truth? :)
    On my re-model, rather than drywall and try to "match" the previous work then prime and paint,we instead did a thinset cement with color added for an old-world look on the walls and ceiling, they added a nice 1/4" bullnose to all the edges and it really looks killer...only downside is it has to dry for 10 days before they can seal it so the fans are running as I type, tile guy was here today laying out the shower and floors. :crazy:
    Hey Laine-O...post up pics of your remodel man! :)
  5. Chevrolaine
    Chevrolaine Veteran Member Gold Member
    3,368
    194
    Aug 5, 2007
    Various barns in N. IL looking for chit.
    lol Probably not enough bandwidth on the site!:eek:
  6. kawboy
    kawboy Veteran Member
    542
    Apr 2, 2010
    Indiana
    I used mesh ONE TIME. I ended up pulling it all back out of a textured ceiling after it cracked and redoing with tape. No more issues after that.
  7. gin man
    gin man Veteran Member Gold Member
    2,310
    103
    Feb 24, 2002
    Morris, Il
    I wound up sticking with tape and if I do say so myself, it looks pretty good. On the inside and outside corners, I've been using this heavy duty tape but in several cases, it lifted some time after I put it on so now I'm thinking I'll go to the steel corners.
