Dual alternator
Discussion in 'Tips 'n' Tricks Topic' started by Dennis Wilkie, Oct 10, 2020.
  1. Dennis Wilkie
    Dennis Wilkie Veteran Member
    177
    16
    Mar 17, 2020
    Yeah, that would be a great idea if I had $600 to blow
  2. dave@ztech
    4,413
    981
    Mar 27, 2016
    NY
    Where in a Camaro do you plan on putting that sub woofer? that thing looks as big as a spare tire , HAA HA, and I would check the amperage for that amp, as what is rated is not what it usually puts out, however you are looking to have to upgrade to 2 batteries, and a big alt and a lot of fuses and 0 gauge wire
  3. Dennis Wilkie
    177
    16
    Mar 17, 2020
    It's an L98 swapped Extended Cab K1500, lol...and i've already seen the amp on a dyno and it runs at 1 ohm stable 3000 rms not peak power. The guy who ran the dyno had 8x1400w batteries strapped and could barely hold it to 13.8v. I already planned on doing the "big 3" upgrades with 1/0 gauge wire, and got a 140 amp alternator a couple of days ago that I still haven't put in yet. I'll probably need a 5 farad capacitor along with a 200 amp in-line fuse
  4. BonzoHansen
    20,236
    1,512
    Jun 1, 2005
    Scott from Hamilton, NJ
    You don't get to build a competition level sound system and then complain about costs lol
  5. Dennis Wilkie
    177
    16
    Mar 17, 2020
    Oh, i've never competed. I've had alot of different sub setups and tried alot of different brands over the years, and I wanna make sure this is the last time. When I was younger, I never cared about rms or matched any power ratings. I'm just covering all the bases to make sure everything is right, and i'm not gonna ruin anything, especially under the hood. I've got so many hours (and dollars) under my hood, i'd rather fry the entire stereo system than have to turn another wrench at this point
  6. Madcow63
    Madcow63 Member
    51
    Jun 14, 2009
    Toledo Ohio
    Have you considered a generator in the trunk?
  7. hd_cat
    hd_cat Member
    32
    Sep 6, 2013
    United States
    I recently discovered ICT Brackets, they appear to be well-made and are affordable. I bought them from Summit Racing, I have them on our '73 Camaro and have bought a second set to install on our '79 Z/28. There may be a configuration that would allow dual alternators. I chose the mid-mount alternator in which the alternator is inverted and the long bolt goes through the bracket and into the cylinder head. The power steering is mounted to the front of the block and water pump, it does not use a header or exhaust manifold bolt as with many others. I have attached a photo of the partial assembly to highlight the design. IMG_2045.jpg
  8. 80NastyZ
    80NastyZ Veteran Member
    189
    13
    Feb 8, 2007
    Poconos P.A.
    Small block
    Big block
    Both setups use CS-130 alternators , 1 straight plate and 1 offset plate , both setups run dual batteries .
    Small block setup uses late 80's / Early 90's steel truck accessory brackets
    Big block uses 88-93 truck accessory brackets
    HTH
    TOM
    dave@ztech likes this.
