Dual mufflers or transverse? pros & cons?
Discussion in 'High Performance Modifications' started by bondora68, Sep 18, 2020.
  1. Coadster32
    2,097
    278
    Oct 2, 2013
    Milford,CT
    While this may be true, it is encouraged to put the H/X pipe as close to the collectors as possible for better results/effect. I am no expert, but researched it a couple of years back when I made an X-pipe for my Camaro. Perhaps someone with a bit more knowledge can chime in and set us both straight.:lush:
  2. dave@ztech
    4,538
    1,023
    Mar 27, 2016
    NY
    I think Engine Masters did a video on the difference between strait and x and H
  3. 80sz
    80sz Veteran Member
    3,648
    580
    Feb 2, 2014
    Buffalo,n.y.
    A test was done on engine masters, they are almost identical in hp gains with x pipe at a ultra tiny extra. Exhaust tone is the difference in two, h pipe more choppy, x pipe more racy. I got the x now and would rather have the h pipe as it sounds better at idle. A extra x pipe in muffler won’t hurt flow.
  4. Roadtrip
    Roadtrip Member
    30
    Jul 4, 2013
    Texas
    If there's an H Pipe in the muffler and the intermediate H Pipe is more cost than straight pipes, why put in 2? I haven't been able to find any info showing a difference related to distance from headers for the H Pipe.
  5. Sanders Speed
    Sanders Speed Member
    50
    30
    Jun 22, 2017
    Iowa
    BillyDean7173 likes this.
  6. Coadster32
    2,097
    278
    Oct 2, 2013
    Milford,CT
    You only need to Google it.
  7. BillyDean7173
    BillyDean7173 Spirit In Black
    2,492
    813
    May 21, 2014
    Hutto, TX
    Exactly. Well stated.
  8. Roadtrip
    Roadtrip Member
    30
    Jul 4, 2013
    Texas
    I've seen that article and others like it that generally conclude "Moving it around can shift the torque peak slightly, but not enough to make a real-world difference.". Since I'm not going to put my 79 in the Daytona 500 :crazy: I'm just wondering out loud if the extra cost of the intermediate X/H Pipe is worth it. Restoring our cars is expensive enough, $20 here and $15 there adds up. An H Pipe designed into the transverse muffler seems like a good compromise to me. As long as the distance doesn't make it ineffective.
  9. 80sz
    80sz Veteran Member
    3,648
    580
    Feb 2, 2014
    Buffalo,n.y.
    The crossover x or h helps share pipes and merge exhaust pulses. It’s a few hp difference on a 600hp motor in the dyno testing on engine masters. Every car being different and lower horses power with yours it would be more of a exhaust note change , the x pipe is smother sounding blends better
  10. DesmoEd
    DesmoEd Veteran Member
    1,222
    64
    Sep 9, 2009
    Frisco, TX
    They do sound distinctly different. I have very similar sbc's in each of my cars, the vette has an X and the Camaro has an H pipe. Both are manual transmission so they idle pretty much the same at ~13.5 in vacuum. The X sounds busier, more modern raspy - the H is deeper and throatier.
    I'm running Hedman 64105 ceramic long tubes with the Flowmaster 17149 system
    Its plenty throaty and the system tucked up pretty nice and came with nice slash cut stainless tips
