$ Mike 70 Z-28
X2 AGREE with 1980rsIf it's an MSD distributor I would lock it in at 35° to see if it helps, the locked in deal sure made a difference for me.
Now that's getting the job done! Put a set of radial slicks on that car and get a free 2 tenths.
I hear you. I'd like to try that with a 7AL-3. I'm currently running a 6AL. I launch it at 5300-5500 rpm. The distributor is fully advanced before 2500. It starts and idles beautifully.
I drove over the scale at LVD at the end of the day. It was 3030#. I'm 230#.
I haven't used the Moroso slide rule, but it seems to be rear hp in this scenario.
It's going through the traps at 6800. It needs a few more rpm to reach 135. A slightly smaller diameter tire would bring the rpm up above 7200 through the traps.
I still need to dial in the suspension for a better launch to eliminate wheel spin. I'll try a minor adjustment to the 4-link to bring the instant center forward and down. I'm also considering 2" drop spindles on the front.
The QFT 950 may flow the same as the Holley XP 850 you dyno'd with. As my first post mentioned, perhaps a Holley "750" XP may tell you a few things.Ran the car at Atco yesterday with NETO at the Yesteryear drags. Essentially no changes for competition day. Car ran a best of 10.23 @ 131. Rpm's through the traps are about 6800. It'll be a few weeks before I get the car to the track again. Next time out, I'll run it with the Quick Fuel 950, and move the Instant center further forward and down. I'm also going to run it with a drop base air cleaner and the hood on.
I think the hood will help you out as well.
