Easiest Front Speaker Options
Discussion in 'Car Audio, Electronics & Security' started by BlueBaron762x39, Feb 27, 2020.
  1. BlueBaron762x39
    BlueBaron762x39 Veteran Member
    102
    May 29, 2009
    colorado
    I have a 1979 Berlinetta Camaro. My stereo is just a basic setup of a Custom Autosound in the dash, two speakers in the rear package tray, and two mounted in a bracket under the dash. My problem is the front dash mounted speakers. They were difficult to install originally and now 10 years later they have fallen apart. Have any of you tried installing front replacements out of sight under the dash in front of the center console or somewhere else in the vehicle? I'm not really interested in dealing with installing another front speaker set in the factory location but don't want to cut up my interior or replace kick panels either.
  2. Twisted_Metal
    27,670
    1,294
    It shouldn't be that difficult to replace that center speaker in a 79-81 Camaro.
    I took the bezel loose and rotated it out of the way... Driver's window down and door open.
    (The headlight switch remained connected and I only had to disconnect the cigarette lighter connection and fasten seat belt light.)
    I removed the cluster mounting screws and left the cluster completely connected to the electrical and speedometer and I was able to swap out the original speaker for one I had gutted and mounted two 3-1/2" speakers into.
    My 80 has A/C and I was able to work around the center duct... All while sitting in the driver's seat.
    It's best to have everything you need at hand because you can't climb out of the car very well with the bezel resting on the edge of the door. ;)
  3. COPO
    18,907
    1,248
    What I did.
    79B2ACAD-4DB8-4BA2-A2DD-356B9EF26D61.jpeg C55BD1B8-49BF-463A-A859-C86D7AB920AB.jpeg 93F4AC21-4746-497F-904A-448BDD1C56F1.jpeg B4E709CB-A5D3-4602-9BD1-581A767A8D77.jpeg 0CDB3A37-DF6E-4B61-A4C0-10183E9B22E1.jpeg 1C3F0D92-AB69-4E76-AA25-994B92976C97.jpeg
    bigdan, mrfleet12, 72BIGBLOCK and 2 others like this.
  4. Burd
    625
    119
    Oct 6, 2011
    $hitty Part of Detroit
    You can put one in each side of the console. Lol. No don’t
  5. Twisted_Metal
    27,670
    1,294
    Unless you’re going to build custom door panels or kick panels... leave it in the dash.
    Adding speakers in those locations usually looks tacky unless you use well designed custom pieces.
  6. Burd
    625
    119
    Oct 6, 2011
    I saw a company do a nice kick one.
    I can’t find the pic, squirrel just bought a car and it had speakers in the back of the sets. Uglier than sin.
    75Maro likes this.
  7. djorgensen3
    djorgensen3 Veteran Member
    570
    80
    Oct 15, 2009
    Peoria, Az
    1971Camaroguy has kick panels for component sets.
  8. biker
    biker Veteran Member
    1,453
    344
    Dec 7, 2014
    New Liskeard Ontario Canada
    Getting at the stock speakers made me wish I took yoga classes. I think it's possible to make (like the guys above did) or buy a good setup with two high quality speakers in the stock location.
  9. grzewnicki
    3,463
    187
    Dec 9, 2009
    Gordon from Jacksonville Fl
    I put a pair of 5 1/2 inch ones with separate tweeters in my kick panels. Cut the duct work off the kick panel, made an aluminum plate that secured the speaker into the sheet metal opening and protected the back of speaker with waterproof speaker cover. Tweeters went up in the top of the dash (unfortunately you pretty much HAVE to have the windshield out to use holesaw to cut the opening for this part). Down that low you'll probably lose some highs if you go with a set of speaker that have a tweeter built in.
  10. djorgensen3
    570
    80
    Oct 15, 2009
    Peoria, Az
