Ecm location
Discussion in 'High Tech Retrofits' started by greencamaro1981, Jan 21, 2018.
  1. 2ndGenCrazy
    2ndGenCrazy Veteran Member
    743
    37
    Aug 18, 2011
    Upstate New York
    You are correct. They make a special plug to use when you completely remove the wire and terminal from the ECM connector. They are color coded for size. If you are using a 98 to 02 ECM, I could look up the source and number for you.
  2. CAMeeks
    CAMeeks Veteran Member
    699
    43
    Jan 5, 2014
    Deer Park, TX
    Grinder ;)
  3. greencamaro1981
    greencamaro1981 Veteran Member
    604
    Jun 2, 2010
    Montana
    IT started today! I only have time to work on it on Mondays, and have been playing with this fiasco since October but I finally have the engine in wired and running! I still have lots of little things to get done but its alive!!!!!
    I am running the 01 computer from the Yukon that was the donor for the swap.
