edelbrock 800 avs / 650 avs carb?
Discussion in 'Engine Topic' started by Riley, Apr 9, 2011.
  1. Riley
    Riley Veteran Member
    132
    Oct 3, 2010
    Nova Scotia, Canada
    What is the least amount of HP/Torque/Vacuum edelbrock 800 avs carb and the edelbrock 650 avs carb would work ok on? any info woulld be great.
  2. dubs74camaro
    dubs74camaro Veteran Member
    707
    Mar 19, 2011
    Big Block, OR
    Seems like an odd question at first glance. You can easily over-carb just about any motor and it's done ALL THE TIME. What makes you ask the question. Can you give us a little insight on why you are asking? Big difference between any 650 and 800 carb.
  3. DoTheDew
    DoTheDew Veteran Member
    899
    Mar 2, 2010
    Leduc, Alberta
    To many variables on that. Engine size (cubes), VE, etc play a big part. There is no real least amount of HP they would work on. Both would run a 4 cylinder engine that produced 40hp if you wanted them to, but probably not very well. 650, you're good up to around 350-400 hp if calibrated correctly. the 800, over 450-500. You could still make the 800 run on a 200 horse 305 if you wanted, but it'll never preform the way a 650 would, if you get what I'm saying.
  4. 76z28
    76z28 Veteran Member
    2,384
    180
    Jun 29, 2009
    bakersfield
    Since its an avs you could use either one I got the 800 for my set up
  5. NYH1
    NYH1 Veteran Member
    1,604
    12
    Feb 27, 2010
    Central New Yorkistan
    Cubic inch x max RPM ÷ 3456 = required CFM @ 100% volumetric efficiency.
    Example- 350 CI x 6000 max RPM = 2100000 ÷ 3456 = 608 CFM @ 100 VE.
    Keep in mind that most street built engines are usually 85% to 90% VE or so at best. So if you put x .85 or .90 at the end of the above formula, you really only need a 517 to 547 CFM carb. A little more won't hurt. Going to much more then is actually required can hurt. Carbs are like cams, you're better off being a little to small then to big.
    HERE is a good calculator.
  6. 1BAD78
    1BAD78 Veteran Member Gold Member
    814
    Apr 12, 2007
    Broken Arrow Ok
    That makes no sence. How did you come up with that?
  7. 76z28
    2,384
    180
    Jun 29, 2009
    bakersfield
    AVS---AIR VALVE SECONDARIES
    It has a spring operated door you can adjust basically to the cars needs which is to allow it to only draw in as much air as it needs
    LEMME GUESS my car is over carbed but thats funny i had a 650 on there and i gained 5mph in the quarter...
  8. 1BAD78
    814
    Apr 12, 2007
    Broken Arrow Ok
    Wrong dude the AVS means Ajustable valve secondary which allows you to change the secondarys opening rate. So what that means is you turn the adjustment screw to speed up or slow down the secondarys opening rate. so your adjusting basically at what point the secondarys open.
  9. Led Zep
    Led Zep Veteran Member
    575
    33
    Mar 13, 2008
    Ky
    At the very least, get a 750 VS carb.The Quadrajet was rated at 750 CFM and put on many a smogger motor with a cork called a CAT.Did they run rich?Of course not.The MYTH OF TOO BIG A CARB,came from people putting double pumpers on every engine thinking they had the performance edge.
    A 600 CFM VS is a joke.Anyone telling you otherwise has no REAL world experience on a dyno or at the track.
  10. dubs74camaro
    707
    Mar 19, 2011
    Big Block, OR
    Wait a minute.....you know NOTHING about this guy's motor combo and you are telling him to get at least a 750 VS???????
    For one thing the conversation is not about Q-jets and why on Earth would Carter (in the past), Edelbrock, Barry Grant and Holley (among others) even make a carb smaller than 750 cfm if it is just not needed???? If you think "over carbing" is a myth, you obviouisly have no dyno or track time yourself. Just saying........
    Dub
    HP Carburetors
    http://feedback.ebay.com/ebaymotors...edback2&userid=hpcarburetors&ftab=AllFeedback
