Have an Edelbrock 1406, w electric choke
Engine has been firing right off but wanted to adjust the a-f mixture using a vacuum gauge. At idle the engine was running kinda rough but this is not a recent change. Idle rpm is about 800.
Drove the car till full warmed up. With the engine running, the RH screw was fully seated but no change in engine running. Then the LH screw was fully seated and engine rpm increased and ran smoothly.
Removed the needles and sprayed carb cleaner into the openings. The LH had a whistling sound but not the RH. On the needle tapered end, I felt some roughness with more on the LH needle. Inserted needles fully then backout 1 1/2 turns and started the engine. Fully seated the RH then LH needle with the same results.
Sprayed carb cleaner around the cab-intake gasket with not rpm change
Circuit blockage? More carb spray? Compressed air? Watched a YT video about Edlebrock a-f adjustment having no affect due to the transfer slot being exposed due idle and fast idle adjustment settings?
Bad needles? Do the rough spots mean the surrounding carb surface is damaged?
