I'm looking at these Aluminum heads for my 327 because my Camel Hump have no accessory and its a pain to find brackets and stuff, does anyone know if these Edelbrock Performer Cylinder Heads will with work with my Edelbrock Performer RPM Air-Gap intake? Edelbrock Performer RPM Air-Gap Intake: http://www.summitracing.com/parts/EDL-75011/ Edelbrock Performer Cylinder Heads Heads: http://www.summitracing.com/parts/EDL-60859/
Make CHEVROLET Liter 5.7 CID 350 Engine Type V8 Engine Size 5.7L/350 Beginning Year 1987 Ending Year 1995 Engine Family Chevy small block Gen I Rocker Arm Mounting Style (application) Stud Application Notes Designed for direct replacement, wil not fit LT1. Should work but in case it doesn't E-street 5089 does. http://www.summitracing.com/parts/EDL-5089/Application/?query=Engine+Size|5.4L/327
Heads: 50-state street legal aluminum heads for 1987-95 Chevy 5.7L engines (except LT1, LT4 and LT5 Corvettes) originally equipped with centerbolt valve covers and the 1987 and (b)later intake manifold bolt pattern(/b) Intake: Edelbrock 75011 RPM Air-Gap intake manifold Fits 1955-1986, 262-400 cu.in Chevrolet V8s Might run into a bolting problem with the center two bolts?
When i go to the Jegs website and look up the heads there it says "Performer Centerbolt Heads Designed for 1987-95 Chevy 5.7L engines originally equipped with centerbolt valve covers. These aluminum heads use the 1987-95 intake manifold bolt pattern." Can someone show me a 1987-95 intake and is there a difference between cast iron heads and aluminum heads intakes? Thanks
I think the Eddy 60899 RPM head will be a better fit if you're looking to turn up the rpm's on that 327. These heads match the RPM Air Gap intake and make a real good combo.
I'm going after the 60859 heads because i know someone selling them for a pretty good price, so i just want to know if i can use my Air gap intake
Only difference betwwen those heads & RPM,s is they have provision for heat cross over & RPM's don't. Even though your air gap doesn't have heat cross over provision it'll bolt on with no issues
Thats not correct - look at Jegs website. They are "Performer Centerbolt Heads" - make sure you read under the correct listing http://www.jegs.com/i/Edelbrock/350/60859/10002/-1?parentProductId=758341 those heads are designed for '87-'95 intake bolt pattern they are small chamber/runner as well (60cc and 165cc) compared to the basic Performer #60909 (64cc and 185cc) The #7501 intake is pre-87 so it will not work I have the 60909 and 7501 combo on my vette motor - its a nice street combo and made excellent power on the dyno Good Luck , Ed
Yea, I honestly can't answer that question, but I'm sure someone here will come in with some experience. If you look that head up on Eddy's site, you'll see that they match it with the 3704 intake, which is a TBI type. Actually, I think these heads are the standard angle and will take pre vortec intakes but I've never messed with them..
