egauges plus Gauges ? anyone got them?
nz70
26
Auckland New Zealand
I'm looking to update my dash gauges anyone got a set of these egauges plus? are they any good ?
I don't want to mix and match and getting the complete package at a ok price looks good? not sure what brand they are though ?
your feedback please
Cheers
Alan
alan frye
bellingham wa
egaugeplus
I just saw these, and so far they look the best for what I want. I am going to call them for some specific imfo on the gauges, and will let you know.
alan frye
bellingham wa
egauges
I called egaugesplus, Don 513-988-8441. The gauges are New Vintage USA. You can go to there web sight. Don states. Plastic housing with gauges, uses stock bezel. All electric gauges, with senders. Back lighting. recalibrating speedo. You can also get this set at Sunitt Racing, same price. Don said if you call him he will sell cheaper.I really like the fact that they are 4 3/8 rather than 3 3/8 speedo and tac.
alan frye
bellingham wa
egaugesplus
I finally got around to odering a set of 6 gauges from Don @ egaugesplus. They are listed as 4.5 inch., but that is the hole size. The os diameter is actually 4 11/16 , which is what Don says the autometer 5 inch gauges are.This is a set of 6, large 8000 rpm tac and large 140 mph speedo. The minors are 2 1/16. I am getting the gauges only, not with the housing, because then you need to use the stock bezel, mine is broke.The main reason I am not getting the housing/gauge assembly is you almost need to take the dash out to get the gauges out, and the repro dash is too flexable to hold the housing securely.I will be making the bezel out of abs, so I wont need the housing.I plan to make some extra bezels ,so if anybody needs one, I will give you a great deal. I will also be documenting the dash build and posting with photos.The gauges are New Vintage,Performance Line.The are all electric and re-programable. They come with all senders.Summitt sells them for $499.00 plus shipping, but Don at egaugesplus can beat that.These are high quality, made in USA, and a lot less than Autometer.
Modifyer
28
Hello. Looking at replacement gauges as my housing bezel tabs are broken & electrical face at the back is damaged. How did these gauges work out for you. Any recommendations? Any comments on Dakota Digital. Thanks.
