EGR or Not EGR
Discussion in 'Troubleshooting & Diagnosis' started by JMA563, Jan 22, 2014.
  1. JMA563
    JMA563 New Member
    18
    Jan 21, 2014
    Coppell, Texas
    Guys, just received a free 1978 Camaro Z28. Needs an intake manifold since the previous one is missing. Owner doesn't know what he did with it.
    When looking to buy a new Manifold, the question comes up. With EGR or Non-EGR? How can I find out if I need the one with or without EGR?
    PS. The car was sold in California - if that makes a difference.
    thanks for your help.
    Jeff
  2. CorkyE
    11,507
    963
    Welcome to NastyZ...
    What are you local & state emission laws? The 78 came with an EGR valve but a lot of us have long since eliminated it, along with the other emission equipment. You don't need it to make it run correctly but maybe to get past the smog Nazis.
  3. JMA563
    JMA563 New Member
    18
    Jan 21, 2014
    Coppell, Texas
    i live in Texas. Never tried to pass an old car like this. I will do some research from Texas to find out the requirements now for old cars.
    thanks!!
    Jeff
  4. middleagecrisis
    middleagecrisis Veteran Member
    967
    Oct 22, 2007
    Fellow Texas resident here. Due to it's age, your Z is exempt from emissions testing. Get whatever intake you prefer, slap it on and go. You can title it for daily use, as a "classic" or an "antique". None of the three options will require an emission test. I wish someone would give me a "free" Camaro!
  5. JMA563
    JMA563 New Member
    18
    Jan 21, 2014
    Coppell, Texas
    Thanks guys. Guess i will go with the NON-EGR since they seem to be the norm.
    I will be back with many more questions.
    Jeff
  6. JMA563
    JMA563 New Member
    18
    Jan 21, 2014
    Coppell, Texas
    Just to make sure before i go and order new manifold. There is no difference between EGR and NON-EGR for my 1978. I am ok going Non EGR, just want to make sure i am not messing up. Don't need $300 mistakes.
    thanks again,
    Jeff
  7. CorkyE
    11,507
    963
    Which intake are you looking at specifically? Some manifolds have a provision to either use or install a block off plate for the EGR. A non EGR manifold will not have a mount for this valve at all. EGR was an early means of bringing a cold engine up to temp and emission reduction as it recirculated a small amount of exhaust gas back through the engine. If you currently have this valve and decide to go with a non egr intake you'll need to cap the vacuum source to it.
  8. JMA563
    JMA563 New Member
    18
    Jan 21, 2014
    Coppell, Texas
    this one from O'Reilly's
    Edelbrock Performer - Intake Manifold
    Part Number: 2701
    Line: EDB
    90 Day Limited Warranty
    UPC: 85347027019
    Cast
    Non-EGR
    Idle-5500 RPM
    Chevrolet Small Block 262-400 CID
    For 4 BBL Carburetor
    Street/High Performance Use Only
    Detailed Description
    Optimized Intake Runner Design - Brand-New; Designed for Edelbrock Square Bore Carburetors; Maximizes Peak Torque Around 3500 RPM; Excellent Throttle Response and Mid-Range Power; Produced +5 HP and +9 ft/lbs. of Torque Over #2101; For Idle to 5550 RPM Street-Driven Performance; Dual-Plane Low-Rise Intake w/180 Deg Firing Order; Also Available Polished Version - See #27011
  9. mjoc
    mjoc Veteran Member
    3,534
    Apr 29, 2003
    Sherman Oaks, Ca
    Just so you know. If it originally came with smog equipment it is illegal under federal law to remove or alter any of it. With that being said YOu would need to go with the EGR manifold.
    BUt if it was me I would get an non EGR manifold. less parts that can break.
    Michael
  10. DoTheDew
    DoTheDew Veteran Member
    899
    Mar 2, 2010
    Leduc, Alberta
    That one will work fine.
