roadrace2
Please provide any feedback for this kit - link below.
www.speedwaymotors.com
I've been reading many threads about hydro-boost systems before posting this thread - but this kit (for 4 wheel disc systems) seems to be a really good set up - I've seen it installed on one of the episodes of "Wheeler Dealers" - again, real life feedback would be appreciated.
Thank you
Compact Electric Brake Power Booster Master Cylinder, Disc/Disc
12-volt electric power brake booster can be mounted almost anywhere System provides up to 2,000 psi of brake line fluid pressure to brakes 1-3/16-inch bore master cylinder designed for use with disc/disc braking system Master cylinder is compact enough to use directly on firewall, under dash, or...
Thank you
