Electric defroster?
Discussion in 'Interior Restoration' started by reinhardt79, Mar 1, 2016.
  1. reinhardt79
    reinhardt79 Veteran Member
    858
    May 12, 2002
    VA BCH, VA
    I yanked the factory heat and a/c to smooth the wall and drop some weight. I use the car as a weekend toy/drag car. Would be nice to have a defrost though, the windshield fogs sometimes on the humid nights at the drag strip. Is there a electric heater I could install behind the dash and pipe to the windshield vents? Lightweight, compact, enough to remove fog from the glass. I don't drive the car in the winter, so I don't need REAL heat. Besides, the headers cook the floor boards anyways.
  2. typeLT73
    typeLT73 Member
    94
    May 13, 2013
    New Mexico
    before you go that route you should try anti fog treatment first.
    make sure you check out the reviews first.
  3. Rust eater
    Rust eater Veteran Member
    133
    Feb 22, 2016
    Chicago Il
    Use a small 12 volt blower. These can be found in the rear ac units on chevy vans. Run some hose from the outlet to the vents. Light simple and easy.
  4. reinhardt79
    858
    May 12, 2002
    VA BCH, VA
    Does the blower have a heating element in it? OR is the blowing air enough to clear up any fog?
    I will try the anti fog treatment first. Thanks for the simple idea. I typically skip the easy solution and skip straight to the major overhaul.
  5. cali cruzer
    cali cruzer Veteran Member
    2,966
    414
    Mar 24, 2002
    Henderson/Las Vegas, NV
  6. mickstan
    mickstan Veteran Member
    927
    Jun 11, 2012
    E'ville, IL
    Just wire up a hair dryer and stick it in the vent system. It will still work even at 12-14 volts!
