electric fan
Discussion in '1978 - 1981 Specific' started by typeomang, Feb 17, 2017.
  1. typeomang
    typeomang Veteran Member
    190
    May 25, 2011
    okc, ok
  2. BonzoHansen
    19,954
    1,268
    Jun 1, 2005
    Scott from Hamilton, NJ
    I used fouth gan fans. Seems to work well, oe quality parts
  3. Bandit723
    Bandit723 Veteran Member
    3,259
    483
    Oct 1, 2016
    Waupaca WI
    I am running dual fans from Be Cool. they work well, but are a little pricey
  4. giggity
    giggity Veteran Member
    1,174
    194
    Mar 18, 2013
    Pearland, texas
    I used Flex-a-lite. Expensive, but really well made....as supposedly made in USA.
  5. ULTM8Z
    ULTM8Z Veteran Member
    9,469
    591
    May 19, 2000
    Los Angeles
    Do a search on Taurus fan. Dirt cheap on ebay and very powerful and easy to Retrofit. Can also download my write up from my website on what I did to install mine.
  6. XxWickedz28xX
    XxWickedz28xX Veteran Member Lifetime Gold Member
    5,980
    May 22, 2001
    Carmel, NY
    I also run electric fans out of a 4th generation camaro. Coupled with the flex a lite variable speed controller, I've not had a problem in years.
    Plus you can just pop in any local parts store for replacement parts for it, and they look like they belong there with very little work.
  7. dailycruiser81
    dailycruiser81 Veteran Member
    207
    10
    May 19, 2013
    ft lauderdale
    4th generation fans nice high power fans. Kept my car very cool. Only reason I took them out was to go with a bigger radiator and then the fans would not clear my gear box. Now I am running Spal, very impressive fans too. Flowkooler water pump also helped.
  8. NeoNeuro
    NeoNeuro Veteran Member
    190
    Aug 4, 2014
    Panama City, FL
    Are 4th gen fans single or dual?
