5 to 20 amps should be sufficient from what i have read any more amperage won't gain you anything. as to the anodes be sure to put one on each side of the part. I have found that i would get better results doing so.
Ok. I am going to add 2 more anodes so I have better coverage in the tank. The 2 pieces of rebar were 5ft long so it covered the full length of the tank on both sides. These are only 17” and they are not fully submerged to avoid corroding the terminal connection.
I will find out more today when I swap in the front leaf springs.
