Elgin E920 camshaft
Discussion in 'High Performance Modifications' started by Bill_K, Nov 25, 2007.
  1. Bill_K
    Bill_K New Member
    29
    Oct 20, 2007
    Livingston, NJ
    Is anyone using this cam in a 9 to 1 compression 350 engine? How does this cam compare to the stock L-79 cam? I have power brakes in the car and wonder if the Elgin cam will cause problems. My rear gears are a 3.73 ratio, will the Elgin cam cause torque problems at low RPM? Thanks in advance, Bill
  2. hubba
    hubba Veteran Member
    204
    Jul 21, 2006
    i think i have run that cam before just don't remember the numbers. let me look and see if i can find them.
  3. Bill_K
    Bill_K New Member
    29
    Oct 20, 2007
    Livingston, NJ
    I am assembling a new engine and this is the cam I am cosidering. The car will be street driven only.
    Bill
  4. hubba
    204
    Jul 21, 2006
    Lift: .480"/.480"
    Adv. Duration: 288/288
    Duration @ .050": 230/230
    Lobe Center: 109
    Lopey idle, good power from 3000-6000, needs headers and gears
    I have run it. in a s10 with 3.73 welded rearend and 3500 stall. it had good midrange tQ
  5. hubba
    204
    Jul 21, 2006
    it has a 107 intake CL i run it 4 deg. advanced. The motor went from the s10 to a 1975 nova with power brakes. they worked fine.
  6. rustbucket79
    rustbucket79 Veteran Member
    9,076
    May 29, 2003
    British Columbia, Canada
    Too much cam for the application.
    Elgin 1029
    Lift: .443"/.443"
    Adv. Duration: 287/287
    Duration @ .050": 214/214
    Lobe Center: 112
    Mild idle, improved power and torque, works w/stock converter
    Elgin 922
    Lift: .433"/.465"
    Adv. Duration: 288/298
    Duration @ .050": 214/224
    Lobe Center: 112
    Mild idle, good low end torque, stock converter OK
    These are the cams you should be looking at
    70Camaro406 likes this.
  7. hubba
    204
    Jul 21, 2006
    if he wants something to drive everyday without a big stall. i would pick something smaller. like a crane 272 you can pick them up cheap and do a better job with a street that you could enjoy
  8. pdq67
    pdq67 BANNED
    10,496
    Jul 26, 2001
    Columbia, MO, USA
    At 9 to 1 CR, I'd strongly consider running this one from PAW!!
    It's a little sucker but should really produce some grunt!!
    PN 10386 spec'd at; 266/209, 110/108, .414"/.414"........
    I figure it is Elgin's E-919-S;
    Last time I looked it sold for $44.95!!
    Now if price is OK, then use a CC 260HE at 260/212, 110/106, .440" lift. But it's probably going to cost $120 or so...
    As always, jmho..
    And I wouldn't go bigger than an Isky 264 Mega at 264/214, 108/108, .450" lift.
    And please note!! NOTHING fancy here at all for a low compressioned street engine.
    pdq67
  9. Bill_K
    Bill_K New Member
    29
    Oct 20, 2007
    Livingston, NJ
    Does Elgin make an L-79 (327/350) replacement cam? This may be the cam I should use.
    Bill
  10. pdq67
    pdq67 BANNED
    10,496
    Jul 26, 2001
    Columbia, MO, USA
    Bill,
    The old -151 cam really need's 11 to one even tho I daily drove it for years in my 10 to 1 CR., L-48 350SS engine way back then.
    And I figure this Elgin cam is their version of the old -151.
    E-903-P; 306/222, 114/110, .447”.
    pdq67
