Emergency brake cables adjusting???'s
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by dickeymoore, Jun 22, 2011.
  1. dickeymoore
    dickeymoore Veteran Member
    116
    16
    May 7, 2010
    Atlanta,Ga.
    I installed some emergency brake cables on my 1974 Z28(from each rear wheel to old brake cable coming from the emergency brake pedal) and when I press the emergency brake pedal all the way to the floor the brakes will not hold the car when it is in neutral,I have the adjusting nut on the cable coming from the pedal all the way out and the cables are pulled tight when the pedal is pressed in,any HELP and my 1974 Z28 is a 4speed manual car.THANKS
  2. Hoot
    Hoot Veteran Member
    1,475
    Jul 12, 2008
    Greenville MS
    Need to adjust your rear brake shoes.
  3. sevitz5
    sevitz5 Veteran Member
    1,618
    Feb 27, 2011
    Middle Point, Ohio
    ^^^ what he said
  4. dickeymoore
    116
    16
    May 7, 2010
    Atlanta,Ga.
    I replaced the rear brake shoes with new ones so just adjust them out and they should hold?THANKS
  5. Hoot
    Hoot Veteran Member
    1,475
    Jul 12, 2008
    Greenville MS
    What I do... Adjust out till the drum starts to drag on the shoes. Then adjust back in a little.
    I have 4 speed and my drive is sloped. Use the ebrake all time.
