End my headache
Discussion in 'VIN, Trim Tag & Drivetrain Decoding' started by HeavyChevy86!, Jan 25, 2021.
  1. HeavyChevy86!
    HeavyChevy86! New Member
    Jan 25, 2021
    Okay it looks to be a 350 with camel hump heads are they original to the block?
    Also is the muncie 4 speed orignal to the block?
    I came up with a 1973 350 with 68-72 1.94/1.50 202/1.60 64cc Heads
    1970 M20 2.52 Wide Ratio LMK what do think
    Thank you!
    Engine code on the front reads : 14N107529V0824CLk
    Back of block reads : 3970010
    Date Code Reads : H213
    Head Right side : 3927186 GM32
    Head Left side : 3927186 GM29
    Tranmission
    Case :3925660
    Patent No :3088330
    Tail housing :3857584GM
    10 Spine with 2 Groves
    27 spine output shaft
  2. Gary S
    23,929
    1,516
    The engine block appears to be from a 1974 Z28 according to the VIN on it.
    The heads are 69-70 64cc heads which could be either 1.94 or 2.02 depending on what they came from and what has been done to them.
    Transmission decodes to be a 1968-69 M20 Muncie.
    All this assumes nothing has been changed inside the units.
  3. tom3
    tom3 Veteran Member
    13,472
    1,024
    Aug 1, 1999
    ohio
    Should be able to find a date code on the heads I think.
