engine block identification
Discussion in 'The BS Topic' started by nasty 79 z28, May 19, 2008.
  1. nasty 79 z28
    nasty 79 z28 New Member
    16
    May 19, 2008
    Watertown,NY
    I have a 1979 camaro with a 350, but it is not the motor that came in it, the block number is 3914680 i have went to many websites and cant find this number anywhere:mad: , i have checked the number a hundred times to make sure I got it right, I wondered if anyone had any info about this block?
  2. BowHunter
    BowHunter Veteran Member Lifetime Gold Member
    963
    17
    Nov 12, 2004
    Wappapello Mo, USA
    Double check to see if it is 3914460 instead of 80 !! If so it's a 68 327 block
  3. Gary S
    24,219
    1,694
    I can't find a 3914680, but Madmike lists a 3914660 here
    http://www.nastyz28.com/sbchevy/sblock.php
    Chevy casting numbers are crude enough that you probably cannot differentiate between a 6 and an 8.
    If it is 3914660, it should be a 1968 327
  4. nasty 79 z28
    16
    May 19, 2008
    Watertown,NY
    I have done that I even striped the paint to make sure the paint didnt make the numbers different, but thanks anyway
  5. nasty 79 z28
    16
    May 19, 2008
    Watertown,NY
    engine was out of a stock car if that helps i did find another person with this block number it was a 350 in a 78 vette
  6. m pozzi
    m pozzi Moderator Staff Member
    2,544
    Apr 9, 2002
    Central California, USA
  7. nasty 79 z28
    16
    May 19, 2008
    Watertown,NY
    I tried that site and no luck im not sure what to do, i was told by the people who owned the stock car that it was a 350
  8. Camarofanatic73
    Camarofanatic73 Veteran Member
    2,373
    May 15, 2005
    Sacto,NorCal
    Maybe they fibbed?
    Have you checked BOP numbers?
  9. nasty 79 z28
    16
    May 19, 2008
    Watertown,NY
    no where are they located
