Engine Compartment Dirty Work
Discussion in 'Body Restoration' started by 74cam_mojo, Jun 26, 2007.
  1. 74cam_mojo
    74cam_mojo Member
    41
    Jun 13, 2004
    West of Chicago
    Can anyone recommend a good Heavy Duty degreaser..... my motor is out so now is my chance to spruce up the eng comp. / I used a few cans of Gunk Engine Brite with w/a power washer, elbow (grease), wire brush, etc.....not working very well........any suggestions?
  2. 74cam_mojo
    74cam_mojo Member
    41
    Jun 13, 2004
    West of Chicago
    Thanks / I'll give it a try.......
  3. 77RS
    77RS Veteran Member Lifetime Gold Member
    2,943
    Oct 18, 2006
    Asheboro, NC
    Greased lightning or POR15 MARINE CLEAN works great. Much better than the gunk. Spray on, let soak, wash off with pressure washer. It's that easy.
  4. BonzoHansen
    20,901
    1,863
    Jun 1, 2005
    Scott from Hamilton, NJ
    +1 or Zep Orange diluted with water (IIRC home depot carries it). Dilute the POR w/water as well. Both very good cleaners - get some $1 spary bottles from HD as well. The GL stuff woirks well too. I used the zep stuff in my bench top parts washer.
    I also second the carb cleaner stuff will tear through paint and kill all living things if you do it at home - you might as well use gasoline LOL. I'd pass on that. It works wonders on cleaning parts on the bench though. Laquer Thinner works good too, and is a bit easier on paint.
  5. Kamikaze
    5,040
    Aug 4, 2005
    So. Lake Tahoe CA. USA
    If you're going to strip it down and repaint, another inexpensive option is to use spray cans on oven cleaner.
    The Easy-Off or other brands for self cleaning ovens are a little less agressive, (not by much!), but are good for the caked on grease and grime, (use a parts cleaning brush to scrub heavy deposits), and you just pressure wash or hose off.
  6. wookie
    wookie Veteran Member Lifetime Gold Member
    3,037
    Jul 12, 2006
    Daytona Florida
  7. 79camaro2001
    4,784
    May 4, 2003
    Monroeville, PA
    you bored mark??
