Engine Gasket Set
Discussion in 'Engine Topic' started by Mottley's79, Feb 6, 2011.
  1. Mottley's79
    Mottley's79 Veteran Member
    104
    May 22, 2010
    New Brunswick, Canada
    I am going to pull my motor to inpect it, clean up the engine bay, install a new transmission and fix my oil leaks. What would be a good gasket set to get? I only need the oil seals, like oil pan, valve covers, rear main seal ect. I looked on summit and seen like 5 different gasket materials for rear main seals? I'm at a loss.
  2. z28rod
    z28rod Veteran Member
    4,472
    Apr 30, 2009
    hopewell junction,ny
    I Would Buy A Felpro Full Kit, Anything You Dont Use Just Wrap Them Up In The Box And You Will Have Them When You Need Them....
  3. z28smokin
    z28smokin Veteran Member
    282
    Dec 8, 2004
    Indianapolis, IN, USA
    ^^+1
    If you skimp you will be sorry!!
  4. falloutboy
    falloutboy Veteran Member
    2,283
    15
    May 1, 2003
    Grafenberg, Baden-W├╝rttemberg, Germany
    wasnt there an engine builders FelPro kit that had all gaskets but at a better price?
    Gasket Material depends on what your dealing with :D
    For a stock engine / car - basic stuff will probably do.
    But some serious power needs some serious gaskets.
