Engine pics
Discussion in 'Engine Topic' started by biker, Aug 28, 2020.
  1. biker
    biker Veteran Member
    4,342
    2,143
    Dec 7, 2014
    Everything coming together slowly. Just waiting on a set of pulleys for the crank and water pump. Top end is all tight, new gaskets, adjustable guideplates, 7/16 studs, rocker arms, double roller timing chain and gears. Painted intake, valve covers, oil pan, bellhousing. Bell is dialed in under .002 runout, hydraulic clutch is installed and ready to go. New alternator and mid- mount bracket, type II pump and block mount bracket. IMG_20200827_1952047.jpg IMG_20200827_1730108.jpg IMG_20200825_1715220.jpg IMG_20200826_1327513.jpg IMG_20200828_1756437.jpg IMG_20200825_1716171.jpg IMG_20200828_1756290.jpg IMG_20200825_1716077.jpg
  2. muscl car
    23,519
    1,876
    Jul 8, 2001
    Gallatin Tennessee
    Looks awesome !!!!! , can't wait for a video of it running
  3. DB Z28
    DB Z28 Veteran Member
    654
    107
    Nov 30, 2003
    Fond Du Lac
    Looks Great it going to be lot of fun their
  4. biker
    4,342
    2,143
    Dec 7, 2014
    Thanks guys! Subframe connectors and solid body bushings too. Once I get the posi in, I will post a good donut video. Then you are next Chuck....
    muscl car likes this.
  5. wiseryder
    2,281
    106
    Sep 11, 2004
    Michigan USA
    Good looking engine ! Hope it runs well for you !!!
  6. xten
    xten Veteran Member
    4,477
    3,561
    Sep 24, 2014
    Pittsburgh, Pa.
    Looks great! I like the intake and valve cover color (colour) against the aluminum heads. Nice work!
  7. biker
    4,342
    2,143
    Dec 7, 2014
    Good work on the spelling upgrade! I wrestled with the colour. Almost went with the GM blue that the original engine came with, but a good clean low gloss black always looks good.
    Zstar and xten like this.
  8. $ Mike 70 Z-28
    $ Mike 70 Z-28 Veteran Member
    1,283
    134
    Nov 7, 2002
    New York, NY
    BIKER, NICE JOB!!! looks good A+A+A+
  9. COPO
    21,357
    2,784
    Brent, is that a GM crate engine? That looks great.
  10. Zspoiler
    Zspoiler Veteran Member
    4,159
    501
    May 6, 2012
    Federal Way, Washington
    And as every part comes in .Its just like Christmas.;)
