engine seems to miss after 150 shot
Discussion in 'Competition Camaros' started by camaro454, May 8, 2012.
  1. camaro454
    camaro454 Veteran Member
    590
    Jan 24, 2003
    Harrodsburg, KY
    engine was running good hit the nitrous a couple of times now it seems to miss while driving starts fine and idles fine.
    Its a 150 shot on 454 bored .030 over forged 10.25 to1 trw forged pistons eagle I beam rods. Comp cams 292/.555 lift hydraulic cam a lifters. Merlin oval port heads with 1.7 roller tip rocker. Edelbrock Air Gap rpm intake 950 profrom carb. Msd Dist. and MSD 6al ignition box with timing control and msd window switch. I turned the timing down 6 degrees and running #8 ngk spark plug and window switch is set for 3000rpm on and 6000rpm off. Im hopeing I havent damaged anything....
  2. camaro454
    590
    Jan 24, 2003
    Harrodsburg, KY
    I decided to pull dist. cap and just take a look this is what i found.
    What would bee the best way to clean this up..
  3. Twisted_Metal
    29,214
    2,219
  4. Louich
    Louich Veteran Member
    2,415
    Mar 8, 2004
    Arthur, Ontario
    thats nasty
  5. camaro454
    590
    Jan 24, 2003
    Harrodsburg, KY
  6. camaro454
    590
    Jan 24, 2003
    Harrodsburg, KY
  7. Turbo70Camaro
    2,138
    116
    Jan 7, 2005
    so cal
    absolutely nothing since it triggers the magnet or buy the expensive billet reluctor, mine did the same exact thing, changed my reluctor and mag pick up and put on a new style vented MSD cap problem solved for me at least :)
  8. Turbo70Camaro
    2,138
    116
    Jan 7, 2005
    so cal
    you can see the hooded vent next to the coil terminal.
  9. muscl car
    23,142
    1,618
    Jul 8, 2001
    SoCal High Desert
    you can also use a very small drill bit and drill into the cap on the sides between the towers so it can vent
  10. camaro454
    590
    Jan 24, 2003
    Harrodsburg, KY
    Where can I get the billet reluctor does summit have the and cap??
