engine seems to miss after 150 shot
Discussion in 'Competition Camaros' started by camaro454, May 8, 2012.
  1. camaro454
    camaro454 Veteran Member
    590
    Jan 24, 2003
    Harrodsburg, KY
    Just ordered the new cap billet reluctor gear and pick up hope this is my problem.... Thanks a lot guys.
  2. Turbo70Camaro
    2,138
    116
    Jan 7, 2005
    so cal
    Word of caution on installing the mag pick up, you need to silicone it in or something like that. I didnt want to deal with it so I sent my dist and parts to msd to do the R & R and while they had it they locked it out for me too since I run a crank trigger. Didnt cost much I think it was like 60 bucks or so.
  3. MechanicMike
    MechanicMike Veteran Member
    520
    Aug 14, 2002
    Long Island, New York
    I noticed the rusting inside my distributor when i freshened my mototr this winter. Had no drivability problems but thought all that rust couldnt be good. I emailed MSD with a picture of the inside of the distributor. They replied
    Dear Mike
    To see rust in the distributor is normal. The rust will not affect the performance of the car. The solution is drill a hole in the side of the cap will prevent this from happening again. The size of hole is 5/32.
    I carefully sanded the rust with an abrasive pad and applied a thin film of di-electric grease and put it back together. Seems to be o.k..Looks like the cap may be the problem. Good luck with your repair.
    Mike
  4. muscl car
    23,141
    1,618
    Jul 8, 2001
    SoCal High Desert
    drilling a small vent hole in the cap is an old hot rodders trick from back in the day !!!!:)
  5. mrdragster1970
    7,821
    507
    Apr 12, 2007
    For a crank trigger, you really should have a hole on #1 so you can phase it properly.
  6. Turbo70Camaro
    2,138
    116
    Jan 7, 2005
    so cal
    Correct sir not quite their yet but I know phasing the crank trigger and the efi is gonna be fun/tricky.
  7. camaro454
    590
    Jan 24, 2003
    Harrodsburg, KY
    Replaced cap pick up and reluctor gear and i still have a bad miss I can unplug #2 plug wire and it doesn't change anything. You guys think I might have a burnt piston...
  8. 79powershifter
    79powershifter Veteran Member
    266
    Apr 22, 2009
    Southgate Mi
    Broken ring land ? Happed to me once with a 150 shot. Rings were gapped too tight for spray
  9. camaro454
    590
    Jan 24, 2003
    Harrodsburg, KY
    Guess Ill just have to pull it out and see....
  10. mrdragster1970
    7,821
    507
    Apr 12, 2007
    Don't pull anything, do a leak down 1st, and check the wires, plugs, ignition etc.
    I meant I always drill the hole above number one.
    Just a habit I guess.
