engine seems to miss after 150 shot
Discussion in 'Competition Camaros' started by camaro454, May 8, 2012.
  1. camaro454
    camaro454 Veteran Member
    590
    Jan 24, 2003
    Harrodsburg, KY
    Did a compression check and number one cylinder is 180 and the cylinder I thought was bad is number 2 and its 175 does this mean my rings are good or could i still have a broken ring land or other damage to that cylinder???
  2. camaro454
    590
    Jan 24, 2003
    Harrodsburg, KY
    Just did a leak down test on #2 and you could hear just a small amount of air coming from breathers on valve covers, compared it with #1 cylinder and it seems to be the same. Guess Ill check that plug wire next..
  3. HOLESHOT
    HOLESHOT Veteran Member
    1,043
    Feb 19, 2009
    mesa,az
    i wouldnt worry if it was my engine. mine hasnt passed a leak down in years and blows smoke out the breathers still makes 500hp so im not worried
  4. camaro454
    590
    Jan 24, 2003
    Harrodsburg, KY
    Iwouldnt worry so much if it didnt miss so bad. Check plug wire it was good guess ill try changing my plugs..
  5. ZS10
    12,166
    Jan 18, 2003
    BC, Canada
    Hyd flat cam? Check rocker movement on that cylinder. Might have lost a lobe...
  6. camaro454
    590
    Jan 24, 2003
    Harrodsburg, KY
    Changed plugs still didn't help seems to surge a little when in gear and light throttle. Gonna check push rod and springs make sure neither is damaged... anymore idea's?????
  7. camaro454
    590
    Jan 24, 2003
    Harrodsburg, KY
    OK pulled the head and intake piston looked good valves look good replaced plug wires. When I rev it in park it revs fine starts great but when I rev it it seems to come back to idle kinda slow. Haven't driven it yet but seems to be doing same thing as before. I unhooked the timing control only thing hooked up now is the 6AL box and window switch I'm out of ideas. could I have an air bleed or something in carb stopped up????
  8. cmonson
    cmonson Veteran Member Gold Member
    4,134
    Apr 7, 2006
    Calgary, Alberta
    Maybe a vacumn leak.
    Could the dizzy shaft be slightly bent?
    I would pop in a cheap hei and see.
  9. camaro454
    590
    Jan 24, 2003
    Harrodsburg, KY
    Gonna try another dist. and ignition box wish me luck.....
  10. camaro454
    590
    Jan 24, 2003
    Harrodsburg, KY
    Tried new dizzy didn't help. I haven't found another ignition box yet. Whats weird is it starts perfect idles perfect but only misses under load and seems to surge a little under light throttle like at 20 to 25 mph.. any more ideas????? Don't think its vac leak i pulled the intake and have all vac lines plugged.
