engine stop when hard breaking.
Discussion in 'Engine Topic' started by matt65, Mar 31, 2020.
  1. matt65
    matt65 New Member
    13
    Feb 14, 2012
    france
    Hi
    I read a lot this forum and most of the time I found the answer to my question without posting.
    This time I don't find the solution to my problem.
    my camaro is 1973, with 350ci V8 and a TH350 gearbox.
    When I break hard the engine stop. the problem occur even if I'm in Neutral.
    I've check the carburator floater level, it ok.
    I've done some road test with break booster disconnected, and still have the same problem.
    A part from that my camaro is running well, start perfectly hot or cold.;etc
    thanks for your help.
    Matt65 from France ;)
  2. dave@ztech
    3,910
    838
    Mar 27, 2016
    NY
    Are you saying that if you are sitting still, and push the break hard the engine dies?
  3. matt65
    matt65 New Member
    13
    Feb 14, 2012
    france
    Hi,
    Nothing happen when the car is sitting still.
    The test I've done in Neutral is in a downhill. Car moving.
  4. Happy_Dan
    Happy_Dan Veteran Member
    1,038
    247
    Sep 13, 2013
    New Boston, NH
    Sounds like something to do with fuel delivery since it's when you stop while moving. The fuel must shift somewhere? Something in the tank maybe?
  5. COPO
    18,796
    1,200
    You probably have a vacuum leak at the booster or hose. Check all vacuum lines and also see it your leaking brake fluid at the rubber hoses. Check your fluid level and you will know if your leaking brake fluid.
  6. matt65
    matt65 New Member
    13
    Feb 14, 2012
    france
    Appart from that problem, the car is working perfectly, cold start and hot start perfect, no cut off engine, good performance.
    I made all the test with break booster vaccum hose disconnected ( and a plug on carburator side) , and still have the problem, so no relation with vaccum line
  7. COPO
    18,796
    1,200
    Check for a vacuum leak around your intake manifold using propane gas.
  8. Twisted_Metal
    27,528
    1,228
    Is it a Q-jet carb?
    Sometimes those phenolic floats absorb some fuel and don't "float" at the correct height even if the measurement is correct.
    (A heavy float allows too much fuel into the bowl before it stops the inlet flow at the needle/seat.)
    If the fuel level is too high and it sloshes out of the bowl, under hard braking or downhill stops, it will "flood" the engine and stall.
    My suggestion... Change the float and recalibrate the level.
    NOT A TA likes this.
  9. matt65
    matt65 New Member
    13
    Feb 14, 2012
    france
    It's a Holley 600. Very common set up why should I had a float problem. :(
    Look my level when engine running
  10. matt65
    matt65 New Member
    13
    Feb 14, 2012
    france
    I will check that but If I have a problem of vaccum at the intake I should have others symptom !!
