everyone with a 502 in here
Discussion in 'High Performance Modifications' started by andrew1977, Oct 3, 2008.
  1. andrew1977
    andrew1977 Veteran Member
    1,499
    Oct 1, 2006
    parksvegas, BC
    iv got a zz502 for my 80 camaro, what do i need to run for motor mounts, and pullys/brackets?
    what kinds of brackets do you run with your belts, pullys, etc?
    got any pics?
    my dad and i are not wanting AC, we have the short water pump, we have no pullys, brackets, anything.
    the only thing we have other than the motor, are the hooker headers that are on the way.
    will stock 267 motor mounts work?
    its going to be a drag car.
    thanks.
  2. no-nitro
    no-nitro Veteran Member Lifetime Gold Member
    1,082
    Nov 17, 2005
    Ofallon MO
    I bought the moroso steel mounts (62630,62515) for the 572 bolted right up with no problems. I still have a set in the basement if you want them. 35.00 plus shipping. On the pulleys a used march mid mount standard rotation 2 belt, but i had to go to a long pump. I think it was around 750.00 for the march setup, but i had to buy extra brackets for a tall deck.
    I can't remember is the 502 a tall deck? If so those headers will not work.
    Here is a pic of the pulleys
  3. Maliboost
    Maliboost Veteran Member Lifetime Gold Member
    7,185
    May 18, 2001
    Im pretty sure the 502's are build with a bowtie 10.2" deck block (tall deck).
    Bob
  4. John Wright
    15,259
    419
    Aug 9, 2002
    Rustburg, Va
    Hi Bob!...;)
  5. kik_start
    kik_start BANNED
    3,296
    Sep 3, 2006
    gone crazy
    + 1...^^ Hi Bob!
  6. MyBoTy
    MyBoTy Veteran Member
    1,567
    10
    Feb 9, 2002
    Lubbock, Texas USA
    502's are definitely short deck engines, headers should be fine.
  7. BlackDog82
    BlackDog82 Veteran Member
    557
    Jul 29, 2003
    State of Confusion
    the ZZ502 crate-motor uses block P/N 10237292, with a deck height of 9.800", and siamesed cylinder walls
  8. rscamaro73
    rscamaro73 Administrator Staff Member
    14,977
    17
    May 30, 1999
    Striking fear and destroying the enemy
    9.8 = regular deck
    10.2 = tall deck
