Exact direct replacement Al radiator for 70-71 Z28
Discussion in '1970 - 1973 Specific' started by Adams, Dec 21, 2018.
  1. Adams
    Adams Veteran Member Lifetime Gold Member
    929
    27
    Jul 16, 1999
    From Motown (still in the blood), live in Houston
    Anyone recommend a direct exact fit replacement aluminum radiator for a 1971 Z28. I want to keep the stock fan and two piece shroud and have the top cover fit right and the radiator sit in the core support properly with the rubber bumpers. Exact fit replacement.
    I have a big block 70 SS that is on it's 3rd al radiator (Champion CC162, Griffin 33-145985-1, Afco AR80255N). None fit with the shroud.
    Thanks for recommendations.
  2. Green hornet
    Green hornet Veteran Member
    2,011
    466
    Oct 11, 2015
    North Bay, CA
    I don’t have a big block but here is what I just installed. I wanted a factory looking radiator and upgraded from the 20 inch factory radiator to the 26 inch , I found it on eBay it’s a KKS radiator under $200.
  3. Green hornet
    2,011
    466
    Oct 11, 2015
    North Bay, CA
    This is what mine looks like. I installed electric fans but still use the factory top plate and original rubber bumpers.
  4. FlaJunkie
    6,417
    246
    Mar 24, 2001
    Rockledge, Florida
    20 inch? In a factory Z28?
  5. 70lt1z28
    4,207
    965
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Z28’s in 70-71 had 2 row core 26 inch wide radiators. Big blocks had 3 rowcore or 4 row core (heavy duty radiator option) 26 inch version.
  6. Green hornet
    2,011
    466
    Oct 11, 2015
    North Bay, CA
    My car is not a factory Z28. I opened the core support and installed a 26 inch radiator for future A/C install.
    The aluminum radiator I show above is a three row core.
    FlaJunkie likes this.
  7. Ote
    Ote Member
    80
    14
    Sep 24, 2017
    Kennewick, WA
    I put a Frost Bite 3 core aluminum in my 1971 Z28. Perfect fit...stock fan, two piece shroud, core support, etc. Dropped right in. It never over heats and has automatic trans cooler. Bought it from Summit for around 270. Part # FBR-FB163 - Frostbite Performance Cooling Aluminum Radiators
    Adams likes this.
  8. Adams
    929
    27
    Jul 16, 1999
    Thanks!
  9. 70lt1z28
    4,207
    965
    Oct 3, 1999
  10. Ken Devine
    Ken Devine Dockroger
    8
    Dec 5, 2017
    Winnipeg
    Just checked my original 71 Z28
    2 core 26”
