Exhaust Pics
Discussion in 'Original Drivetrain Topic' started by hot72rod, Jun 15, 2015.
  1. hot72rod
    3,019
    39
    Aug 9, 2000
    Phenix City Al / Columbus Ga
    I'm looking for some pics of how the exhaust hung under the car from the factory. I thought I had taken some of my car, but I seem to have misplaced the file.
  2. 70 SS/L78
    2,890
    135
    May 5, 2005
    Rockford, MN
    I have some pics but need to find them on my computer at home. There are 4 hangers on a dual exhaust car, 2 at the top of the hump above the rear axle for hanging the muffler and 2 farther back on the rear frame rails for hanging the tail pipes. There are no hangers forward of the rear axle.
  3. hot72rod
    3,019
    39
    Aug 9, 2000
    Thank you.
  4. CamarosRus
    CamarosRus Veteran Member
    8,543
    147
    Feb 16, 2000
    Auburn,WA (between Sea & Tac)
    Scott, Do you have the best ever pics of Jack Seymours Hugger Orange 70' Z-28 exhaust, as do I ????
  5. 70 SS/L78
    2,890
    135
    May 5, 2005
    Rockford, MN
    Chuck, I have a few of Jacks pictures but only what I found on a link in a forum several years ago. You most likely have more or better pics than I do.
  6. SDL73Z28
    SDL73Z28 Veteran Member
    152
    Oct 4, 2014
    NJ
    Here is a pic of the muffler hanger and how it is attached to the clamp, I couldnt find a pic of the bracket for the tail pipe right now, hope that helps.
    [​IMG][/URL]
    [​IMG][/URL]
  7. hot72rod
    3,019
    39
    Aug 9, 2000
    Thank you. It does help but it looks like you are missing part of the bracket.
  8. 70 SS/L78
    2,890
    135
    May 5, 2005
    Rockford, MN
    The picture posted above is not correct for an original factory setup. There are no muffler clamps at the top side of the muffler, only on the bottom. The tail pipes are welded to the muffler but it uses a hanger that wraps around the short sections of pipe exiting the muffler at both ends.
    Not sure how much these will help you but here's all I could find from my car... somewhere I have more pics from other cars that I still need to find!
    [​IMG] [​IMG] [​IMG] [​IMG]
  9. hot72rod
    3,019
    39
    Aug 9, 2000
    I concur with you 70 SS/L78. The pic do help, once I blew them up I can see which way the mounts are bolted up and which way the clap comes out.
  10. 70 SS/L78
    2,890
    135
    May 5, 2005
    Rockford, MN
    Here's some more pics I found in my files that should help you. I believe this info is also in the AIM, that's what I used.
