Exhaust too low.
Discussion in 'High Performance Modifications' started by NC70, Nov 26, 2021.
  1. 73Z L92
    73Z L92 Veteran Member
    348
    132
    Jan 25, 2011
    Carlos, MN
    I've used the 2.5" mandrel bend kit from Summit a couple of times with good results. To get the mufflers closer to the floor the pipe that runs from the header collector to the muffler can rotated so the muffler can moved up closer to the floor. I don't care for the pinched bends done at a muffler shop.
    Zstar likes this.
  2. G72Zed
    G72Zed Veteran Member
    3,496
    1,911
    Sep 8, 2015
    Flowmaster had a "U-Weld-it" kit that I used, 3" all mandrel bends, with a few feet of straight 3" pipe, I had enough material for a complete exhaust, with full length 3" tail pipes (1972 Z28), and another exhaust on a customers car with turn downs at the rear end (1980 Malibu).
  3. Zstar
    Zstar Veteran Member
    2,761
    985
    Mar 23, 2014
    Ocala, Florida
    Also check your rear transmission mount. They go bad and help the exhaust hang down due to the drop angle.
  4. Zspoiler
    Zspoiler Veteran Member
    4,159
    502
    May 6, 2012
    Federal Way, Washington
    In a Camaro there are indentations for the mufflers in these cars.So if your exhaust is done correctly .Its should be tucked .
  5. NC70
    NC70 New Member
    8
    Nov 6, 2017
    Thanx for all the great answers, and several options too. it wont be a problem much longer.
