ext.door handles
Discussion in 'Body Restoration' started by 70RSZ28hugger, Sep 28, 2019.
  1. 70RSZ28hugger
    70RSZ28hugger Member
    82
    Nov 30, 2006
    San francisco bay area
    I want to replace or rechrome can someone direct me to good aftermarket parts
    Or do i send out to chrome shop for plating ?
    also need the following parts
    badges emblems
    soft rubber
    thank you Joe
  2. Twisted_Metal
    28,310
    1,692
    Beware of reproduction handles.
    There have been a couple of threads in the past year or so where there were problems with fitment.
    If they aren’t pitted badly, your originals can be rechromed.
    hubedobeedo likes this.
  3. grzewnicki
    3,499
    214
    Dec 9, 2009
    Gordon from Jacksonville Fl
    Gotta watch the length, I believe the later years are longer by 1/4" and aftermarket replacements I think are the longer ones, so better to get originals re-chromed. Hopefully someone with a little more knowledge chimes in.
  4. hubedobeedo
    hubedobeedo 3rd times a charm
    595
    207
    Jul 18, 2013
    Huntertown,IN
    i was thinking about the door handle thing the other day now i am worried because i cannot find my old handles and have bought new o boy
  5. bodymanbill
    bodymanbill Veteran Member
    1,586
    1,175
    Feb 1, 2007
    South Park Pa
    Had my originals rechromed after hearing alot of bad reviews about the aftermarkets , pretty sure they only cost me around $75 a piece and they look perfect.
    74Z28GC3 and hubedobeedo like this.
  6. BradySmmrs
    BradySmmrs New Member
    23
    Dec 14, 2017
    Utah
    I have a set, that I'm pretty sure they're original that I'd be willing to sell from my '71, I suspect they would need to be re-chromed but I honestly cant remember since I pulled them last winter. If you're interested I can pull them out of storage and take some pictures. I'm planning on doing the Kindigit smooth handles, so I won't be needing them.
  7. 70lt1z28
    3,913
    863
    Oct 3, 1999
    Beavercreek, Ohio, USA
    grzewnicki had it a bit backwards. The 70-74 handles are wider than the 75-81 handles by about a 1/2 inch or so. The aftermarket handles are made like the later handles. The aftermarket handles do break I am told, but this could also be due to the door hinges being worn. When the hinges are worn, the door sags and you have to lift the door to open it which the handle was never designed to do. Even the GM replacements in the late 70's and 80's when they were made were like the later handles.
    The later handles can be used, but you will have to file one of the openings in the door a bit wider as the pivot part is wider. This doesn't show once assembled.
    If you decide the rechrome your originals, you may want to follow this guide:
    http://nastyz28.com/threads/1970-74-75-outside-door-handle-disassembly-restore.320197/
    It depends on how anal you are.
    The inner part is actually yellow di-chromate plated and not chrome plated.
  8. astroblue70
    astroblue70 New Member
    Aug 27, 2019
    Scottsdale Az
  9. astroblue70
    Aug 27, 2019
    Scottsdale Az
    I replaced mine on my 70 with classic industries they were 35.00 apiece and they are not bad its been about a year and they still are ok.
  10. 70RSZ28hugger
    82
    Nov 30, 2006
    I appreciate all the help thank you guys
    mike from GF auto so city . 70 rs ss with recaros
