Factory tach with aftermarket HEI
Discussion in 'Troubleshooting & Diagnosis' started by Elliott Taylor, Dec 17, 2020.
  1. Twisted_Metal
    29,072
    2,127
    I’ve heard people have had problems with an MSD ignition system and the factory tach but a “normal” HEI will work fine.
  2. COPO
    20,375
    2,163
    My Tach wire on my 70 is connected to the MSD 6AL Tach terminal cause it would not work in the factory position on the coil.
  3. biker
    biker Veteran Member
    3,066
    1,297
    Dec 7, 2014
    My 77 Z came factory with HEI. Then went to DUI HEI, plugged right in and tach worked fine. Same with my 81.
  4. Elliott Taylor
    Elliott Taylor Member
    68
    Nov 24, 2020
    Awesome. I feel better about the whole issue now
  5. Coadster32
    2,171
    307
    Oct 2, 2013
    Milford,CT
    I also have a 6AL MSD box, hooked to the brown tach wire with factory tach. No issues.
  6. Chuck71RS
    1,673
    296
    Nov 24, 2012
    Houston, Texas
    Having idiot lights and the large fuel gauge, you will need to replace the printed circuit on the back of the instrument housing. Tach and full gauges is part of the u14 set up
    My 71 Camaro had indicator lights-large gauge and I had to change the printed circuit. Some additional wiring changes were needed to the 12 pin plug that inserts into the pc. You will find a sticky about this in the Electrical section but some of the plug wiring might be different for your 1977. Compare a 77 wiring diagram to the sticky
    If the tach needs servicing contact tachman.com. Daniel (Gauge Marks) has retired. His email address is no longer valid. I sent him an email a month ago and it was returned as not a good address.
  7. joer
    joer Veteran Member
    245
    Sep 25, 2008
    East Brunswick, New Jersey
    Did you cut out tach filter? or just cut off end and splice new wire to MSD box.
