Factory tach with MSD6al.
Discussion in 'Troubleshooting & Diagnosis' started by joer, Dec 26, 2020.
  1. joer
    joer Veteran Member
    245
    Sep 25, 2008
    East Brunswick, New Jersey
    How can I get my factory tach to work off my msd box. 79 Z/28 need help.
  2. sandlapper
    sandlapper Veteran Member
    850
    318
    Oct 9, 2020
    SE CSA
  3. joer
    joer Veteran Member
    245
    Sep 25, 2008
    It's an old msd-6420 box. I always ran a after market tach. The tach started to jump around. Could be the tach so i changed it. New tach still doing it. I called MSD. Might be the tach plug on the box. What i want is to not use after market any more. Why not use factory tach. What i want to know is how to connect factory tach to msd box. Using sum-850050 distributor.
  4. Zspoiler
    Zspoiler Veteran Member
    4,087
    476
    May 6, 2012
    Federal Way, Washington
    There is a filter for those .If not in your manual contact MSD
  5. joer
    joer Veteran Member
    245
    Sep 25, 2008
    I talked to MSD. He said something about cutting out filter. After you cut out filter can you splice a wire from the end to MSD box?
  6. COPO
    21,095
    2,616
    My MSD 6AL is a model 6420 cause I didn’t want to go digital and my brown Tach wire works on the Tach connector at the MSD box.
  7. sandlapper
    850
    318
    Oct 9, 2020
    SE CSA
    Just what he said
    that's what it says in the instructions I linked above; mid-way down page 7. "Bypass In-Line Filter"
    JMO, for a motor that's primarily street ... a good, stand-alone HEI dist is hard to beat. Hot fire & dang-near bulletproof & parts readily available. Have run HEI in CT race cars. I've also run CD boxes in CT race cars; still have spares (suggest you travel with spares as well). Ya know, before Cup went EFI, they all ran a dual-trigger dist and TWO coils & TWO CD boxes; all redundant with selectable A-B switchgear. Always brand new stuff but boxes still puke.
    wiseryder likes this.
  8. joer
    joer Veteran Member
    245
    Sep 25, 2008
    My set up is the same as COPO. Old 6al 6420. I'll look for the brown wire and change the end. Plug it in and see what happens.
    Bills69 likes this.
