Father&Son's 80Z28 Project
Discussion in 'Project Progress' started by BP80Z28, Apr 12, 2009.
  1. Wynder
    Wynder Veteran Member Lifetime Gold Member
    332
    Jun 20, 2009
    Nashville, "Music City USA", Tennessee
  2. BP80Z28
    BP80Z28 Veteran Member Lifetime Gold Member
    1,153
    Sep 2, 2008
    Plymouth Mass
    Thanks. I found that. I was confused with that at first. I wasnt reading it right.I get it now. example you measure line A in that direction then the other way.
    Points C&D should be the pints to use.
  3. 76_TypeLT
    6,394
    149
    Jul 26, 2008
    Houston, TX
    you can use just about any factory holes or marks on the frames to produce multiple diagonal measurements. Bolts through the alignment holes will get you close but these extra diagonal measurements will get you spot on.
    In terms of adjusting with the motor in. I suspect if you used bolts in the alignment holes then you won't need to move the s/f much, if at all. That would mean loosening the s/f bolts just enough so you could take a come-a-long or a BFH and do some minor adjustment.
  4. BP80Z28
    1,153
    Sep 2, 2008
    Plymouth Mass
    Thanks Aaron. I didn't have to much time to work on it today.But after measuring a couple of areas of the sub frame it was off like 1/8th". The problem is with the nose cone one side is good. I think its the core support is off.
  5. 76_TypeLT
    6,394
    149
    Jul 26, 2008
    Houston, TX
    Yeah, 1/8" isn't going to cause the type issues you are seeing. I would stick with the plan you have now to get things straight.
  6. phat80
    phat80 Veteran Member
    1,023
    13
    Jan 4, 2013
    Victoria BC
    wow
    Just looked through your thread. You're a machine!
  7. BP80Z28
    1,153
    Sep 2, 2008
    Plymouth Mass
    Thanks. Not much going on with it lately Ive busy processing Deer.
  8. BP80Z28
    1,153
    Sep 2, 2008
    Plymouth Mass
    Well deer season is over. It ended yesterday just one more to do.Time to Put the the equipment away for another year and get the Z out of the tent and in the garage.Plan is to get the interior done and lights back in.:bowtie:
  9. mumu74
    mumu74 Veteran Member
    139
    Jul 31, 2011
    canada
    Hi
    need little info to weld floor pan and rear quarter can i use mig linclon 180HD ?is it important to use with gas? or i can weld without gas too?
  10. BP80Z28
    1,153
    Sep 2, 2008
    Plymouth Mass
    I did this with just the flux no gas.I would recommended using gas if you can. It was the first time at wielding. I took my time and worked my way all around at different spots. That was a long time ago I did those floors. Cant wait to get back at it.Its been a tough winter around here!!!
