Figured out how to finally get the car to hook better
Discussion in 'High Performance Modifications' started by 1980RS, Aug 23, 2020.
  1. 1980RS
    1980RS Veteran Member
    4,599
    1,303
    Jun 17, 2006
    MN
    I am going to take out the Turbo 400 and put a P/G in the car. May have to put more gear in the back but it will make the car hook better with less gear multiplication going from a 2.48 gear to a 1.76 first gear. I sort of had the same trouble in the 90's and stuck in the glide and the car was actually quicker and faster the 2 speed over the 3 speed. I know the next few engines are going to make a lot more power than this little 406 Vortec deal so I just need to settle the car down a touch.
    muscl car likes this.
  2. xten
    xten Veteran Member
    3,760
    2,593
    Sep 24, 2014
    Pittsburgh, Pa.
    If you go to different tracks where prep is different, it will be more consistent too. And I know you know you can get different ratios for them for low gear. I wouldn't mess with the rear gear yet.
    1980RS likes this.
  3. muscl car
    22,806
    1,389
    Jul 8, 2001
    SoCal High Desert
    1980RS likes this.
  4. 1980RS
    4,599
    1,303
    Jun 17, 2006
    MN
    I have a good friend that races a 1968 Nova 4dr with a 505 BBC in it with a glide. He has always been spot on with that car and when he used to race on the street with the P/G the car hardly ever lost a race as he would hook and the other guys spun.
  5. Fbird
    4,937
    1,107
    Feb 12, 2011
    atlanta, ga
    hooking up the 1/2 the battle...especially in the 1/8 mile. All the power in the world means NOTHING if you can't put it down.
  6. dcozzi
    dcozzi Veteran Member
    3,767
    869
    May 1, 2002
    Phoenix, AZ
    Also, robs less power.
  7. Dave Nelson
    Dave Nelson Veteran Member
    4,928
    3,557
    Dec 19, 2003
    Vineland N.J USA
    Buy the Door Slammers Chassis book written by Dave Morgan, this is the bible for drag racers on getting a car to launch and hook.
    xten likes this.
  8. Fbird
    4,937
    1,107
    Feb 12, 2011
    atlanta, ga
    ^^^^ AMEN^^^^^^
    btw ..expect to read it cover to cover .....at LEAST 4 times before you get it! ;)
    Dave Nelson likes this.
  9. 1980RS
    4,599
    1,303
    Jun 17, 2006
    MN
    A buddy went racing last weekend and said he was on Lay's potato chips track, put 100lbs. of sand in the trunk and hooked right up. I might have to try that.
  10. dave@ztech
    4,411
    981
    Mar 27, 2016
    NY
    Works great in the winter!!
