finished-amp install glove box pic
Discussion in 'Car Audio, Electronics & Security' started by Chuck71RS, Jun 12, 2016.
  1. Chuck71RS
    1,740
    340
    Nov 24, 2012
    Houston, Texas
    Turned out to be a tight fit so it took a lot of fitting, install, remove-repeat. Covered all sides with black felt. A groove was drilled on the underside so the wood base would fit over the hump in the horizontal support rail. A terminal barrier is on the underside to connect the amps to the 10ga wire going to the battery.
    The yellow wire is for the receiver. Covered the barrier strip with a piece of plastic from an old note card box
