Could someone please help me identify a firewall black and blue wires with a 2 post flat connector? It's located around the green wires for the temperature sensor on the passenger side. 1970 Z28 Camaro Thanks
This diagram shows a B and DBL wire for the TCS solenoid near the temp sensor. Could those be the wires you are looking at? http://nastyz28.com/camaro/wire/70-engwire.jpg
Yes that looks like my plug but with a blue wire instead of the green. I'm missing the TCS sensor does it mean throttle control sensor? thanks again
TCS is transmission controlled spark. A switch in the tranny controls vacuum advance to the distributor for better emissions.
So.. are they (tcs ) required on a non stock car .... ...copo’s car is stock (pretty much ) But let’s say a car like mine , not stock intake or carb - 4 speed Muncie ... Should it be disconnected if Not required ??
My smog pump is seized so I removed the pump and the pipes going into the manifolds and bypassed the vacuum switch on the intake and just ran a hose from the dizzy can to full manifold vacuum and left the rest connected. After 50 yrs, half of this stuff probably doesn’t even work.
