First pass....finally...
Discussion in 'Competition Camaros' started by fuzzy dice, Feb 7, 2015.
  1. fuzzy dice
    fuzzy dice Veteran Member
    651
    Apr 16, 2008
    Deltona, Fl.
    Thanks for the offer but 4:10's won't do it...I seem to recall doing the calculations a while back...I do know the Wallace site is completely off when I tried that...
    It said with 4:30 gears and 28" tires at 120 mph trap speed I would go through at 6100 rpm...I am at 7000 rpm around the 1000' mark I know for an absolute fact...
  2. BlackDog82
    BlackDog82 Veteran Member
    557
    Jul 29, 2003
    State of Confusion
    the Wallace site usually doesn't factor-in converter-slippage
    I didn't think 4.10's would do the job, but wanted to make that offer to you
    I would think that 3.90's (minimum, maybe 3.70's?) is what you'd need to run 1/4-mile, but that might kill your 1/8-mile times, which is what you run 99% of the time
  3. vegas1974z28
    4,673
    129
    Jan 10, 2002
    Las Vegas,NV
    Wallace number are quite low....says I have a 4.50 gear (4:10) says I go thru the traps at 6100 (6800) says my tire size is 25.6 (28)....so yeah its off a bit.
    I KNOW the convertor plays a huge roll in this but, 28 in tire 5500 stall trap around 125 (ave) and I go thru the traps at 6800...maybe your convertoe is too loose?
  4. fuzzy dice
    651
    Apr 16, 2008
    Deltona, Fl.
    Heavy as my junk is I really like the way the 4:30's get me going...I also like the way I hit the tree with them...thanks for the offer anyway, Dog...
    My converter is a 5200 stall and fairly loose...I have it that way because I leave off the foot at 3200 rpm...again, I bracket race so whatever I leave on the table doesn't matter so much...
  5. mrnitrous
    mrnitrous Veteran Member
    584
    May 12, 2008
    Anaheim Ca
    4.30's and 28" tire and you can't make a 1/4 mile pass??
    what RPM you spin it to? that thing should be fine with that gear tire combo for the 1/4
    Hell back in the day, when we would set up our big blocks cars for the motor we would run 4.88's :crazy: :crazy:
  6. fuzzy dice
    651
    Apr 16, 2008
    Deltona, Fl.
    I am right at 7000 rpm at 1000'...if I set my tach to 6800 rpm the light comes on at 900"...
    While my motor will take going through at 7300 it will shorten the life of the motor...I am a bracket racer and don't need to be doing that...heck, 95% of my events are 1/8 mile anyway here in the south...it's all good...
