First project car 72 Z
Discussion in 'Project Progress' started by Nick_72z, Dec 21, 2019.
  1. lightly-modded
    lightly-modded Member
    69
    33
    Oct 3, 2018
    New Hampshire
  2. hubedobeedo
    hubedobeedo 3rd times a charm
    524
    166
    Jul 18, 2013
    Huntertown,IN
    i got full length goodmark floor(not complete floor just sides) used what i needed and had to fab up the rest of toe for drive side.were cross brace is by seat area i split the difference so underneath the seam would be hidden.i also rebuilt the inner rocker on drive side before install of pan,those are multi layered in that area boy that took some work to make right but now it's solid.from what i could tell the damage probably started when the column seal got destroyed by brake fluid which also ate the finish off the sheetmetal .being hidden under carpet and toe trimplate was just a matter time.the piece of sheetmetal in floor area was there when i got it they had 4 rivets holding it in place LOL
    Nick_72z likes this.
  3. Nick_72z
    Nick_72z New Member
    12
    Jul 19, 2019
  4. Nick_72z
    Nick_72z New Member
    12
    Jul 19, 2019
    That's all bondo and duct tape that was used to cover the holes on the driver's side.
  5. stafs05
    428
    26
    Dec 26, 2007
    chicago,IL
    On ebay Jeggs sells these, here is the item number 312537378471. Sometimes they have a sale.
  6. Nick_72z
    Nick_72z New Member
    12
    Jul 19, 2019
    Is there any need for bracing if I cut out the whole floor pan on one side? Rather how much can be cut out before bracing is required? Thanks
  7. av8r1965
    av8r1965 Member
    69
    22
    Sep 19, 2015
    Wichita, KS
    It depends on how you are supporting the car when you cut the floor out. I'd say if you keep it supported good in the stiff areas, that you won't have a problem without bracing.
  8. Nick_72z
    Nick_72z New Member
    12
    Jul 19, 2019
    It's sitting on dollies, wheels are still on it.
  9. mallard
    mallard Veteran Member
    722
    165
    Oct 3, 2013
    SK, Canada
    Good to know I’m not the only one who hates the “fake RS” front look. :eek:
    dadgonebroke likes this.
  10. Nick_72z
    Nick_72z New Member
    12
    Jul 19, 2019
    Can someone tell me what the trick is to taking these knobs off? 15772093882741831157850531125396.jpg
