Flatspotting on your tires is a REAL thing....
kenny77
3,319
Ft. Lauderdale, FL
Guys,
I've been using a set of Flat-stopper things made by Race Ramps under my tires ever since Xmas.
I can tell you without any doubt THEY WORK. I have no thumping or strange vibes now after I pull the car out after sitting for weeks.....and drive up to 60-70 mph. It would usually go away after about 10 miles....but it was still annoying as hell.
These things are the real deal. They work.
full
21,779
I have never ever had a problem with flattening. In the winter I put in 40 psi and in the spring let it out to 34 psi. In the winter I have plastic and cardboard under the car to keep the moisture off the under body.
CorkyE
11,783
Same here.
80sz
sup
Feb 2, 2014
4,032
Buffalo,n.y.
then are expensive tho .... but ya id like a a set for the zl1 , heard they don't last long and rubber starts to peel? give us a update down the road
Gary S
24,585
The last tires I had that flat spotted from sitting were the old nylon tires. After the manfacturers switched to rayon and then polyester I never had that problem again even if the vehicles sit for months at a time.
Apr 30, 2015
70
Southern VA
I had a 2000 SS that I owned for several years and the tires would definitely flat spot when the car sat for a few weeks without moving. Drove me crazy! I think these flat stoppers would be great for a car that sits a lot.
