Floor mounted gas pedal 70 z28
Discussion in '1970 - 1973 Specific' started by Rich Gershman, Jul 29, 2020.
  1. Rich Gershman
    Rich Gershman Member
    56
    May 21, 2017
    If a 1970 Camaro was not a Z28 would it have the 2 holes in the floor panel that secure the floor mount for the gas pedal. Were the 2 holes present with any Camaro and then the holes were plugged if not a Z28 option?
  2. Twisted_Metal
    28,456
    1,778
    I believe a non-Z28 only had dimples in the sheet metal to locate the holes for the floor mounted pedal bracket.
    No plugs... They were only drilled to mount the Z28 pedal bracket.
    It's not just the pedal and bracket which were unique to the 70 Z28s... IIRC, the throttle rod was also Z28 specific to function properly with that pedal design.
    flowjoe likes this.
  3. l16pilot
    1,933
    171
    Dec 13, 2004
    Hurlock, MD, USA
    ^^^^...what Terry says :)
  4. Rich Gershman
    56
    May 21, 2017
    Thanks you for both responses. In my case I do have the correct upper throttle part for a Z28 and the holes in the floor. I suspect that the previous owner put in a new carpet and was too lazy to install the floor bracket and pedal. Most everything points to my car being a real Z28 but without paperwork I can't really be sure.
  5. 70lt1z28
    3,951
    871
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Around here you don't have a real Z until you post photos!:p
    TommyRS70, DRAGON64 and VIZ28 like this.
